Larry's Shee
    6
Everything posted by Larry's Shee
  1. Get yourself one of those steel clutch baskets.
  2. Must be free, I don't see a price. Without being able to prove it runs/drives/shifts you're going to loose an ass load. Nice looking though!!
  3. Well, is he asking to tune what he has, or what's in the mail?
  4. You on drugs? He has stock pipes, filter, no lid.
  5. It's not what you forgot, it's what you may have not learned. Try a stock OEM stator/pick-up coil.
  6. Stock OEM or aftermarket stator? Is pick-up gap set and checked atboth nubs on flywheel? Even though it has passedleakdown test, have you inspected carb boots by flexing them to look for cracks? It/they may only leak with vibration.
  7. Clean the carbs, set the float level, install new plugs. Check that the carb caps have rubber gasket in them. Check that carb boots aren't torn, cracked, flex them around, don't just look at them.
  8. That's what electrical testers and wire diagrams are for. IIRC, the kill switch goes to ground in off. Key completes circut when on. If key is removed make sure elimination splice is still good.
  9. Thick skin and hair on your ballz is what ittakes to hang here. You want PC go to the (black) White House or Blue Fairy Forum. Oh wait, that's Blue Trax.
  10. 03+ poor mans drag axle, banshee in blaster for wider, fuel if blasturd is mix, brake pads if 03+, air in tires.
  11. So do you have stock or Chiwanese CDI?
  12. Don't believe us? Call a fucking stealership, they are real fucking helpful. 3GG what? That's just a batch # WHAT don't you get? They're all the fucking same!!
  13. ^^^^ YEP YEP ^^^^^^^^ PO welded washer to shaft, aint never coming off
  14. How the fuck would you get them that square in the corner? Flat file? Has good time/area values
  15. Other than I wouldn't buy dog shit from that fuck
  16. Most with basic bolt ons run 27.5 Carbs clean? Synced? Float set? Clean air filter?
  17. Check all connections, grounds, switches, run seperate ground from coil back to engine
  18. Did you set float height while you were playing? Start with air screw 1.5 turns from lightly seated. Sync carbs by sight or touch at least. Make sure cables are in carbs and cable splitter correctly. If you have tors, can't help you with idle
  19. Who the fuck buys 150$ foot pegs? Pics of your $1g shocks? Good drugs for that Okie
  20. The end of the wire can get corroded where cap screws in. Make sure timing nubs on flywheel are clean. Set pick-up gap, check at both nubs.
  21. Have you done a plug chop? (or read if you know what you're doing) Are they genuine Mikuni jets, or AM bullshit jet kits? What size pilot jet? Too small Pilot will cause bogging. Difference in stroke would have little to do with jetting. What plugs and timing?
  22. Float level is a specific height of the float to gasket surface. Really sounds like you need a Clymers Repair Manual or find the download on here. As far as jets are you just going to say they are in the carbs, or will you actually mention the size so we know what you really have going on?
  23. If you knew it all, you wouldn't have to ask. I know nothing more than meth is meth (chemically). But I bet a piece of yo old lady's ass that cheapo depo meth and "racing" meth are two different things. That's like saying weedwacker oil is just as good as Klotz (enter "your" fav) OR prove us (me) wrong. Get a couple gal and some whacker oil and tell us how you did.
  24. IIRC, it goes something like tighten inner to 35ft/lbs, hold inner while tightening outer to 270ft/lbs, back inner against outer 3mm.
