Hey guys,
I'm new to working on a Banshees and I'm having a little issue with mine. The quad normally starts on the first or second kick even when cold. The engine runs ok with the Choke ON, but as soon as I take the Choke OFF, one of the two cylinder shuts off, like if it wasn't getting enough fuel. What confuses me is that sometimes the RIGHT cylinder shuts off, and sometimes the LEFT cylinder shuts off. It is not always the same one.
I have cleaned both carbs 3 times.
The main jets are CLEAN (did some research before and found that normally a cylinder would shut off with the choke off, because of a dirty main).
Replaced the fuel petcock with a new one. Checked fuel lines and are good.
Spark plugs are new.
Fuel Cap flow is good.
Here is a video of whats going on.
http://youtu.be/ZwpsZZtKtP4
This happens with either the air box on, or off.
Could an air leak on the choke tube between the two be causing this? Any suggestion will be very appreciated. Thanks.
