4wh331in6
    1998 64.75mm stock pipes
4wh331in6's Achievements
  1. I've had the spring slip out and lodge in gear preventing you from kicking that was on a dirt bike not sure setup is the same but worth a look pull clutch cover
  2. Just have snorkel part removed lid still there
  3. I will make sure they are still synced
  4. No I do not have idle screws installed I was using the tors screws to set idle. I will try that setting again thanks will order tors elimination kit with screws
  5. Yes stock. just snorkel removed maybe reeds they are not stock but have stock type Reed stops could be Boyeson stock cage
  6. Gonna buy another couple sets of plugs and do a chop
  7. I thought they were kinda low but the starving for air thing
  8. Unplugged tors was acting up badly unplugging them fixed the uncontrollable wot getting caps soon Runs Pretty Good Except Had To Remove Snorkel
  9. Yes stock no snorkel lid is on its like 80 degrees
  10. I'm not racing this thing I just don't want to burn up new top end
  11. I removed snorkel no nest but runs good without snorkel
  12. Running with 200 mains 25 pilot and needle center position at 670 ft above sea level. Also new uni filter and bored 30 over wiseco pistons. Whenever I install air box cover it Bogs
  13. No air leak.. Runs great only with air box cover removed. I'm at 670ft with 200 mains and 25 pilots needle center position.Turned out air screw to three turns with no change. brand new uni filter bored 30 over wiseco pistons please help really want to keep cover on.I run in sand mostly
