rdzbangshee
Everything posted by rdzbangshee
  1. Ive never had one fall out if its prest in there it could cause a problem you don't want that ill go bang my stock mikunis and see if that washer falls out ill be back
  2. i use hondabond semi hardening on the cases good luck with it
  3. Ive melted the banshees electronics on times and spent about a grand on the electrical to get it fixed every time tits up
  4. i use a stock CDI with the timing cranked to the max .the aftermarket CDI unites don't look good to me unless i owned a blubbery smokin 4 stroke
  5. i would get a new one they should not fall out
  6. my bitches wouldn't no what to do with it ill have to ask the cute neighbor girls for a pose i guess sniff sniff
  7. my 200w stator makes 16.5 volts with two 100w halogen bulbs and i run a rm 400watt regulator it don't hurt to run less watts on the bulbs
  8. you nead some picture dude
  9. AND FOR THE ICE SO I DONT BREAK MY NECK YUT
  10. the gncc itP21/11/9 i like i can use stud cold cutters in it they are about a 100 bucks A PICE AND 21 FRONT MAX CUT WITH 200 STUDS IN EACH TIRES WITH 54 WHEEL BASE AND +5 ARMS UP FRONT AND STRAPD SUSPENSION
  11. your cylinders are probably polished smooth as a baby but probley o piston wash or less take some pictures of the pistons when it blows up will tell you what was wrong
  12. my dumb brother rings were almost 1mm of he burnt up vito's pistons i told him he had a been crank but he sad ow it looks go he was wrong his old rings had a melt down they he rebuilt and had another on in no time
  13. Ive herd vito's has a bad rap for people holing there pistons but Ive had o problems with my vito's engine kit they no what do if you ask them about it 98 percent of the time you run it 6 jets to lean and burn a hole in the piston . it makes me sick when i here there piston bust rings and hole the pistons on every engine build in the first 3 hours . be smart not stupid people.
  14. I would like pics and info about it plz
  15. you need new gaskets you screwed up big time
  16. Athena comes with junk pistons woods port for 50 hp i have the Vito's kit with there welded crank . RDZ racing looks like a good kit i have not tried them out yet .
  17. just line up the nipple you busted a skirt didn't you
  18. just wait tell thy have some 32 inch rims they will be sick ha ha
  19. that's the first thing banshee owners do to give it that fart can effect for your fat ass and run 100 to 1 in the gas then let the bitch run it on strait gas ha ha
  20. i now my floats are bent about a 1 mm apart they are not even the last time i looked at them they may have bent out of Wac float adjustment is a pain you will still burn your engine up if you adjust them
  21. that happens when you bend the floats even they bog out they need to be bent in between sounds dumb huh but mine are bent to shit they work awesome
  22. well with stock jugs you will need a 7mm plate or some custom aftermarket jugs it can all become a stealth kit if you look around for the right kit it requires a custom port Job to get it timed right there's allot of different combo kits out there that no one tried yet a customized deck height is the way to go is they say for more reliable hp without blowing the pipes off or snapping the chain every time you get on the pump gas word i can talk new engine design for years the problem is getting one then brag about it peace out bros
  23. we want pics of the damage it helps allot we love to fix busted stuff
  24. i turn my light on at a low idle when its at 12 volts they blow out on a high idle hope this helps never blown a bulb yet
  25. your better of with little pods they are for drag racing with a 18 inch filters you will probably get a 2 percent increase on the air flow i would have TO CUT THEM DOWN TO FIT MY LARGE CARBS
