rdzbangshee
Everything posted by rdzbangshee
  1. also being so cold on the lake here in Alaska i get a little moisture in the stator cover and wipe it clean after each run I'm thinking a moisture problem when i get on the gas it pulls hard up to the top but i have to let of to 3/4 throttle hit in the rev limiter .I'm going to get a stock oem stator and slap it in see if it helps any. its faster than s";it as it is tops out @ like 75mph i never tried that race gas ever ether. my temp is no hoter than 130 ,my engine wants something to heat up and become a raging screamer.
  2. i pulled a couple like that clean it and see if it works if its melted its junk i have seen the stator cover fill with water after years of no maintenence cold her in alaska i pop the cover all the time to wipe it dry
  3. i fish for cod salmon and halibut my stator had the two voltage regulators and a bad ground blowing bulbs fixed it now my engine temp is no hotter than 130 in this 40 degree weather I'm hitting the rev limiter & 3/4 throttle with keihin 35s a.s.k's it's taking a long time to get this engine to break in banshees kick ass makes my ears bleed seriously. banshee loves twee-kin
  4. i have been thinking of making some carbon fiber tube extentions, 3 or 4 inches long ,by 2 1/4 or 2 3/4 inch wide, with a bracket to to hold it tight to the frame
  5. i had a set on my 87 they were answer sa pro's with fmf mid pipes they where to quiet for me so i switched to fmf silencers twice as loud
  6. i have the rdz eliminator cyl kit super torquey and fast they do some good work go for it dude
  7. 180 is OK any hotter is not .get a aftermarket coolant impeller or a bigger radiator for 100 degree weather if you hit 200 on the temp turn off the engine and let it cool down . my vito's rdz 421 4mm never goes more than 130 on my rad cap temp gage .but it is 40 degrees outside or colder her in alaska with a aftermarket billit impeller and stock radiator. good luck
  8. you guys are right about rm and rs being junk time for me to go stock .I'm sick of my rm stator i must of blown 200 $ on bulbs .
  9. im up for a trip i ride nothing but my banshee or a boat fuck the on road shit hit me up it sucks riding alone
  10. hello ya shees going going gone in a heart beat 4 sec missile I'm having stator issues good luck with it chow
  11. banshee runs good tell 3/4 throttle then fades out to wot the rm stator is reading 11.1 ohms on the red to green wire i have tried like 20 different main jets still running like crap on the top end tried moving the timing from 0 to +7 still no top end maybe i need to try a stock stator which i have not used my mod are on my profile i been trying to figure this out for a year now and it wont go away buy itself please help i keep pumping 1000s of $ into this banshee
  12. had that happen to mine a little splash zone putty fix it a little hole but leaked a little jb weld works with no leaks on tiney cracks
  13. sounds like a crank bearing let go tear the engine apart i had the same problem with the banshee i bought last year the crank was bent tore up the case
  14. use good oil for racing 32 to 1 your engine will last longer and be easier to tune looking at the pspark plugs once in a will witth
  15. they make a big bore kit but no picture
  16. the timing should be @ least +4 to wake up the 4mm crank and make it start to scream mine is set @ +7 with 24cc domes with .160 over bore and don't ever drop a flywheel on the ground get a adj timing plate
  17. i have a new 421 stroker and i have the same problem i think its the rev limiter if i gear up the ratio i go faster wot loads up the engine a little i think it could be my t5 pipes to witch are mid/high version i have used many outboards that ran best 3/4 throttle and flat on top you don't want to rev to high and shatter a pistons and crack a head from reving over 12.000 rpm or 13.500rpm
  18. hi dude i have a couple of shit pile banshee for parts some people and there junk lol
  19. he young dude how are ya
  20. hello hi how do ya work this site i cant figure it out you live in alaska like me whatrs up
