power
    europe
power's Achievements
  1. Ok thanks.i checked on ebay now.vitos are selling pistons and they say this: This is a complete top end piston and gasket kit. The superstock pistons were designed to add H.P. to stock unported cylinders. We basically ported the piston instead of the cylinders, the top of the piston on the exhaust side has an angle cut to let the exhaust escape sooner.(the same thing can be achieved if you raised the exhaust port with a porting tool) The intake windows are raised for a longer intake duration. A solid 8-10 H.P. can be gained after installing these pistons. Re-jetting of the carburetors will be necessary to accomadate the extra H.P. --------------- Up to 10hp extra?cant be true.
  2. Hello. Anywhere in usa they sell good pistons?(stock) for a good price.
  3. Ok thanks.
  4. ahh thanks..now i found it..thanks alot for the help.i might need to put a little bottle or so there.it has never happend before.untill i started to drive on the ice.fast in corners.
  5. I went out to check now.i cant find the went line for the gear oil..i might be blind right now lol..but where is it? i only saw 2 went lines back of the engine.the ones coming from the carbs.
  6. ic.it happend to my friends banshee to after hard riding in corners.only in left corners.
  7. Hello. It has happend onetime now that the gear oil spits out when i drive fast left corners on full throttle on 6th..its a pain in the ass since the engine will be covered with oil all over. Do anyone have a close up pic where the oil are coming out from?i need to make a little oil catch tank i think.
  8. Ok sounds good guys. Think i have to order some sand tires then lol.dont think they sell them in europe.so i have to order them on ebay.
  9. wow nice vids.looks like fun lol. Do all of them use the sand tires on those vids? And if you drive hard in the corners the front dont slide out?i mean you got to work real hard to push it around without sliding out to much?
  10. Hey,whats the name of those sand tires up there? I'm looking for the best front tire out there to put studs on lol. If its possible,please get one to film you while you are out driving hard in corners.i wanna see how good they are.
  11. Ok thanks for the advice.nice pics.
  12. Ok.so i dont have to put on the lowering kit infront?
  13. Thats a nice bike you got there. Mine is all stock,only got some fmf fattys on it.i went from maxxis with studs over to ching cheng i tink the name was.8" rims back,9 in front. Now i feel i have to bump my ass a little bit hard down on the seat to get the power down out of the corners.so i thought it would be bether if i put the lowering kit on.
  14. Hello. I wonder what position i need to set the rear lowering kit on? second,third or fourth?reason i ask its because i dont want to stop and adjust this out in the cold while i'm out driving lol. This is for driving on the ice.
  15. power
    Ice set up
    Hello. If using r6/r1 rear shock.do you guys also use a lowering kit to? If anyone got pics of their banshee with blaster shocks and r6/r1 shock on please post them up.
