xTHUNDERCATx
1 Follower
    lemoore ca
    89 j arm 10 mil on alcohol shearer oof sb/sf 38mm mikunis gravity fed
Recent Profile Visitors
3,693 profile views
xTHUNDERCATx's Achievements
HQ Soldier
HQ Soldier (2/5)
8
  1. I found everything, thanks tho.
  2. Items located in the reno NV area I have a set of new 513 series 64.00mm wiseco pistons/rings. We're going to a 421 so there is no need to keep these around. asking 115 shipped Toomey T6 pipes, severe bluing one spot looks like it was broke through and the previous owner just gobbed up metal to plug the hole, small dent in the other. asking 125 + shipping Stock carbs with pods tors removed 60 shipped, I dont have a pic of the pods at the moment but they do not have outwears.
  3. What did you want for them?
  4. I'm looking for a set of 33-35mm keheins either pj or pwk. Also needing pods, throttle cable, and intakes with them if someone happens to have all of it.
  5. Bump,got the lock up/cover. Still need tires
  6. I'm looking for 9 or 10 paddle triple buff extremes. Also looking for a luck out and cover (direct drive or mattoon) Let me know what you have. Money ready.
  7. We will be there. We're coming in Friday morning. Have a new PPS 421, then our wildcard 421 and 10 mil.
  8. ^ last sentence in the final paragraph. I almost missed it, only caught it after i reread it.
  9. Unless I'm misreading it you already solved the problem. Your carb slides are stuck, pull you carb caps off and follow the throttle cable find why it's binding.
  10. The only other two I'm seeing are new, got links? If I end up having to go new I'll just snag a set from a builder.
  11. Thanks, unfortunately 1 has some dg silencers I'm not interested in. The other I'm pretty sure has a hole in the expansion chamber so I'll pass on both of those.
