vulvafan537240
    15
Everything posted by vulvafan537240
  1. to each his own i guess. ive never ridden bikes so ive always been used to thumb throttles. i guess if you grew up on bikes you might feel more comfortable with a twist. its just dangerous if youre not used to it.
  2. you'd probably be the only bidder. bid like 20k! lol :yelrotflmao:
  3. what kind of compression gauge? crappy comp gauges can give some crazy readings.
  4. what does the left plug look like? replace both plugs. also switch plug wires and see if the problem moves to the right cyl to rule out a spark problem.
  5. no. the long rod's only function is to put less side load with the piston on the sleeve, making the engine more reliable. long rods are 5mm longer and are used with the wiseco 795 series pistons. you must buy a stroker crank to increase the stroke. if youre going with a 4mill stroker, you might as well get the long rod. cost is the same and it adds life to the engine.
  6. if you switched throttle cables make sure you synced the carbs. also replace the plugs if they were wet.
  7. better call jeff at f.a.s.t for some new pistons. get em bored locally. $330 sounds about right for a topend.
  8. what mods?
  9. i think aftermarket jugs, cases, and crank etc are fine and should still be considered a shee. with all the aftermarket parts available how can you blame someone for swapping inferior parts for stronger, faster parts?
  10. you said the crank was a 4011 rigth? thats a stock stroke, long rod crank. long rod 4mm cranks are part number 4111.
  11. those flames look pretty good 05special. hbomb used to make some bomb squad graphics that looked pretty good but theyre discontinued now . i was just about to order brand new white plastics just for these graphics but i called alba to get them and they told me they were no longer made :: . im just glad i didnt order the plastics first.
  12. www.amrracing.com
  13. as long as it has a banshee motor and a banshee frame its still a shee. it can have aftermarket jugs, carbs, pipes, axle, a-arms, bars etc but its still gotta have the 2 stroke screaming twin and the frame imo.
  14. you talkin about the cost of boring? just get them done at a local machine shop. i got mine done for $30 a jug. of course prices are different for different places but get it done locally so that you dont have to pay shipping.
  15. boring usually costs between 50 and 75 bucks. pistons are between 150 and 200. oddball pistons would probably be more rare and more expensive. so in the end, itll probably cost the same either way. i would bore it and go with the .80 over pistons because then you have a fresh top end. :thumbsup:
  16. if your pistons say 65.92, you definately dont wanna go down to a 65.50. like Bansh-eman said, the next size is 66mm which is .80 over. get a micrometer and check the diameter of the cylinders (or get a machine shop to), get some pistons, give them to the shop and have them bore the jugs to match the pistons.
  17. i would start at around a 300 main and a 27.5 pilot and the clip in the mid position. whats your elevation?
  18. ive seen the post that i think you were trying to post the link to and yes the vitos pistons are made by wiseco (custom made to vitos specs) and they claim that using their pistons is like porting the jugs. i cant believe that they are anything comparable to porting, and i wouldnt say that you should go and change the jets right away. i would do a plug chop after re torqing the head nut each time after a few heat cycles.
  19. yeah, merry christmas boys and girls
  20. you should be able to get wiseco pistons up to .100 at rmatv, motosport, magic racing, F.A.S.T., and most other atv parts places.
  21. i live in southeast alabama. we ride at albany sometimes. we're actually supposed to go ride there sometime this weekend.
  22. ive heard that some of the billet ones are so thick that larger front sprokets wont clear them
  23. black on black is the best color combo imo. looks good!
  24. what are you waiting for? get one. with all the features you cant go wrong with it.
