Sheesbest
About Sheesbest
  • Birthday 02/05/1967
Contact Methods
  • Website URL
    http://
  • ICQ
    South Africa Sandton
  • Interests
    Banshees, Trail, Desert, Enduro riding.
    4mill Hotrod crank; Wiseco,s;Durablue axle;Long range tank;Pro Taper bars.
Sheesbest's Achievements
  1. True.
  2. I,m going to put the cylinders back with the spacer and machine the head until i get 0.035 squish. And then start lookin for a better setup.
  3. I,m sure that the solder touches the cylinder wall and stays there while turning the motor.
  4. I think that if it was a 4mm crank the squish would have been less than 2mm.
  5. Can only be a cylinder problem not rods or pistons. Do you think the base gasket thickness should increase to compensate for the problem or should I have the domes cut.
  6. I checked the stroke when Alcoholbanshee asked and it measured 54mm. No spacer plate on the stock setup. Did not take notice of the old base gasket before sending it in.
  7. These cylinders might have been decked before I dont know. Why did I not have this problem with the stock crank and pistons. I thought that the 795 pistons made up for the 5mm longer rod.
  8. Stroke 54mm and the base gasket stock.
  9. Pics of TDC and BDC .
  10. Stock base gasket. The cylinders are ported, and I dont know who ported them.
  11. Do you want me too remove the flywheel and then take a pic of the crank.
  12. 795M06600 on the piston and the crank Hotrod 4011 5mm Long Rod.
  13. Stock head. 2mm spacer plate.
  14. Spacer plate removed. Pistons are knocking the head.
  15. Why would the local stealer install this spacer with a stock stroke crank. The squish is more than 2mm as it makes no marks on 2mm solder wire.
