vulvafan537240
    15
Everything posted by vulvafan537240
  1. cick here this is the link to sync your carbs
  2. yeah hurt him and repo your shee and use the insurance money to make it crazy fast! :woot:
  3. not many things changed for the 20 years that banshees were made. the most signifigant change was from a "j arm" front suspension to a a arm. and i think in 2000 or 2001 yamaha added a brake light instead of just a tail light. never ridden a j arm shee but it doesnt seem as stable as a arms.
  4. did you sync the carbs when you put the new throttle cable on?
  5. i usually dont like cut fronts but shees look good cut. i think yamaha shouldve race cut shees from the factory. i bought my front fender pre cut.
  6. if you dont want to add another switch youll need to hook the TTs up directly to a "hot" wire (bypass the low beam switch). then wire the RSs with the high beam switch. the low beams will be on all the time but there is no other way to keep power to the low and high beams at the same time. you could always add a switch for the low beams though. this would probably be best.
  7. alba has em http://partsfinder.onlinemicrofiche.com/Al...;A=208&B=39
  8. maybe with your left thumb if you have the factory switch?
  9. YOU MIGHT HAVE HEAVY DUTY CLUTCH SPRINGS WHICH WOULD CAUSE A HARD CLUTCH PULL. IF SO, REPLACE 3 OF THEM WITH STANDARD SPRINGS. A NEW CABLE COULD BE PART OF THE PROBLEM ALSO.
  10. yeah buy a replacement thumb throttle cable for a TORS removal kit. motion pro sells them and i think toomey does also. got mine from magic racing. be sure you sync those carbs when you replace the cable or it wont run good at all. p.s. i take it that your a texas fan. im a tennessee fan. at least one UT is doing good this year! lol.
  11. f.a.s.t. racing has mattoon cases. farmandsandtoys.com
  12. you did sync the carbs right? i replaced my twist throttle cable with a thumb cable and didnt sync them and it ran like crap!
