vulvafan537240
    15
Everything posted by vulvafan537240
  1. welcome to the hq :thumbsup:
  2. the left plug is wet and raw gas is coming out of the silencer. when i give it gas it bogs real bad.
  3. yeah this thing is kickin my butt! ive tried all of the simple stuff that i know of. the only other thing i can think is to take the filters off and rule out the filter itself like INFINITIED said. could it be that i flooded it really bad and it just has to burn all the gas out? i re synced my carbs while i had the filters off with the gas on so im sure it flooded it. but you would think that it wouldve burnt it out after a week.
  4. i believe the 485 is a 4mill crank and a 72 or 73mm bore which means youd have to bore the cyls, get new sleeves, and bore the case. how do you like the cheetah? a 485 cheetah is what i want to build but itll take alot of money and it wont happen soon.
  5. you talkin about the tube that goes between the two carbs? i checked that already and its fine.
  6. i looked at my fenders this morning and the rad cover and gt cover dont look noticeably different in person. NOW POST THE PICS!! IM STARTING TO GET IRRITATED!!! JK. :biggrin:
  7. this is the first time ive cleaned the filters since ive had em so i thought that i mightve over oiled em, so i cleaned em again and put no oil on em this time. still the same result. its dark now but tomorrow ill try it briefly with no filters.
  8. this is the first time ive cleaned the filters since ive had them so i thought that i mightve over oiled them, so i cleaned em again and put no oil on em this time. still the same result. its dark now but tomorrow ill try it briefly with no filters.
  9. hey fellas. well just like the title says, i cleaned and oiled my k&n pods about a week ago and its been running really rich on the left side since then. it takes like 20-25 kicks to get it started and then it bogs really bad when riding. the left pipe is cold like its not even firing. i did ride it around my yard one time and revved it wot and the pipe warmed up so i know its not a spark issue. the filters were very dirty so cleaning them should make it run leaner if anything right? any help would be appreciated. thanks. mods are: stock carbs 290 mains 30 pilots needle on 4th clip (second from bottom) k&n pods 4mill crank with spacer plate (stock port) pro circuit pipes boyesen reeds
  10. 4mill cranks do not require any case mods. i think the most common 4mill crank is the hotrods crank. it is highly recommended that you have your crank trued and welded. most companies (F.A.S.T. racing for example) can weld them for you. as far as lifespan goes, they are just as reliable as stock.
  11. i went with silver and carbon fiber plastics just because its different. you dont see very many silver shees around but you cant beat all black plastic on a black frame imo.
  12. kinda looks that way in the pics but ive never noticed it in person. its nighttime right now so ill look tomorrow. looked through all my pics and it looks darker in all of them.
  13. no prob dude. now show those pics!!! :mad:
  14. tallpaintball253 has a topic (http://www.bansheehq.com/forums/index.php?showtopic=103925) about this very same idea. you can get the carbon fiber radiator cover and gas tank cover from jlatvproducts.com but you can only get the front and rear fenders in carbon fiber directly from maier to the best of my knowledge. http://www.jlatvproducts.com/Merchant2/mer...duct_Code=18958 http://www.jlatvproducts.com/Merchant2/mer...duct_Code=18959 heres a pic of my cf radiator and gas tank covers.
  15. http://www.jlatvproducts.com/Merchant2/mer...duct_Code=18958 http://www.jlatvproducts.com/Merchant2/mer...duct_Code=18959 :thumbsup:
  16. if you havent already ordered the radiator cover and gas tank cover i would suggest that you check out jlatv. theyre a little cheaper than ordering straight from maier. as far as the rear plastic, i dont know of anywhere else that carries them in carbon fiber besides maier.
  17. ive had em for about six months now. where are you getting yours? i got mine from jlatvproducts.com. theyre not the cheapest for maier plastics, but theyre about the only ones that carry the carbon fiber colors other than ordering directly from maier.
  18. man youre teasing us! you dont have to worry about the plastic chipping if its maier fenders. theyre just plastic with some kind of carbon fiber looking finish. heres mine.
  19. YEAH I HAVE THE TRAILTECH VAPOR ALSO. MINE STOPS MAKING POWER AROUND 10K BUT MY MAX RPM READS 11370. GUESS I GOT A LITTLE EXITED ONE DAY AND AND 80MPH WASNT ENOUGH.
  20. yeah they look stock to me. it looks like they still have the TORS system on em. idk my TORS was removed when i bought my shee. whats wrong with the carbs?
  21. i think this should be moved to the humor forum. this is one of the funniest topics ive ever read! ahahahaha!!!
  22. man i thought all of the rednecks were in bama!!! hahahaha! :yelrotflmao:
