pr0blumz
Everything posted by pr0blumz
  1. I would advise you to perform a leak down test as well, if you haven't already.
  2. 140 sounds about right with a port job.
  3. I had a bog like you described and had to jet down 3 sizes on the pilot.
  4. Did you ever get a chance to ohm your stator?
  5. Holy big pilot, Batman! You should be real close on the main.
  6. Wow! Why don't you tell him how you really feel! Did you ohm out your keyswitch?
  7. Are your carbs in sync?
  8. What's the rest of your setup?
  9. If you don't have any air leaks, try going up 1 notch on your needles.
  10. Is your filter(s) clean?
  11. 300 mains, 27.5 pilots, middle clip on needle.
  12. My CDI failed because of a wire in my harness shorted out against the head on the motor. I have never heard of them failing for no reason.
  13. I say go with Kevin @ HJR. Great guy, prices, excellent customer service and a 2 week turnaround. That's like a sore d*ck, you can't beat it!
  14. Make sure the wiring harness has a good ground to the frame as well.
  15. Yeah and not having it ported for the 4mil kinda defeats the purpose of going with stroker crank.
  16. What's the intended use of the bike?
  17. Don't think you will gain anything from that.
  18. Are your carbs in sync?
  19. He lives in CA. He's three hours behind EST.
  20. Did you ask Kevin what the jetting should be? He should be able to get you pretty close.
  21. 330 seems a little rich for your set up. Do a plug chop.
  22. Pm Kevin, username KEVSWS6, on here or call him at the # in my sig. He will be willing to answer any of the questions you have with your build. He's one of the nicest guys I have had the chance of dealing with.
  23. The cub cylinders do not require any port work out of the box. I think you're going to need a drag port though to reach atleast 90hp on race gas.
