im going through the same shit right now. My stator tested fine and so did the coil..i even swapped a coil. If you have a ohm meter, go and test your key switch and the kill switch. test the coil,check all the wiring and then the last thing it could be is the cdi box. if your coil is bad, i have one i can send you and you can try it. i have a cdi and a stator on the way now. if ya know anyone close by with the same plug-type cdi, swap em out and see if it fires.
