pr0blumz
Everything posted by pr0blumz
  1. Here's his # 601 918 8745
  2. Reeds could be bad as well
  3. Your pilot is way fat. Try a 48-50
  4. I had the same type of problem and found out that my plug caps were shot. It sounds like you're on the right track by getting new caps.
  5. You should do a plug chop at 150 and take it from there. From 150 to 140 is a big jump when you haven't done a chop yet.
  6. Why are you still running an airbox? Do you have the PJs set up right because they are a pain until adjusted correctly.
  7. Ohm your switches. On/off switch and key switch.
  8. Low compression....time for a rebuild .
  9. Great seller and received item as described. Great communication and fast shipping. Thanks
  10. What are you mods and current jetting?
  11. Too lean, try 48 pilot and 162 main
  12. I knew that was coming! Lol
  13. Tried new plugs and tested your coil?
  14. Test your coil and end caps.
  15. I noticed mine done the exact same thing when I got my motor back from Kevin as well. I think its normal. I just increased my idle slightly until it went away.
  16. pr0blumz
    Parts
    I also need a stock shifter.
  17. pr0blumz
    Parts
    I'm looking for a boss intake for 35mm carbs, a set of 35 PWK's and filters, and a set of v-force reeds. Let me know what you have. Thanks
  18. Ask Kevin @HJR what your jetting should be. His user name on here is KEVSWS6. He had me almost spot-on when I was running the very same setup.
  19. I agree, sounds like you need to sync the carbs.
  20. I received my bumper the same way. Mine was a little more beat up than yours though!
  21. Just get bigger domes so you can keep the bike.
  22. I'm 45 minutes from it.
