pr0blumz
Everything posted by pr0blumz
  1. Reeds on that side could be bad also.
  2. Noble's One Stop ATV Shop 155 E Porter St, Jackson, MS 39201
  3. Are you in Ms?
  4. Care to enlighten us?
  5. Get some larger cc domes. Might be able to get away with 20cc domes since its drag ported. Your compression too high for pump gas.
  6. Yes, both get screwed in all the way. Seems as if you have them mixed up with the air screws.
  7. I corrected the tag on your first post.
  8. 27.5 pilot and 300 main. Start there and do a plug chop.
  9. 35 PWKs, 48 pilot, CEL on 3rd clip, 162 main
  10. Sounds like an electrical problem.
  11. Is that A fuel filter?
  12. Wow!... is all I can say
  13. Do a leak down test before starting to check for airlecks or you will be rebuilding again.
  14. 3. Prices are mandatory! This is not eBay or an auction. Failure to post a price will result in deletion of your post.
  15. Another guy I know says that his friend's Banshee does 115 through the 1/8 and its spinning all the way through. He also say that if it wasn't spinning then it would probably do 119. Ha!
  16. This guy I know, let's call him Chuck, bought a stock cylinder and stroke drag bike for 5k. Lol, yeah I know. Oh yeah, its drag ported on race gas and still has the stock carbs too. Anyway, the bike ran good on race gas for what it was. So, Chuck decides to run a K&T drag ported 421 cub drag bike on alky....it wasn't pretty! Then Chuck decides get his bike switched over to alky...on stock carbs. He takes his bike to the self-proclaimed "banshee guru" and gets it back with the carbs leaking alky out the overflow tubes and the guy told him "its probably something stopped up in those carbs." The guy then tells Chuck, "you can't ride around now since its on alky because you don't need to get the motor too hot and that will mess it up." We raced this past Saturday and Chuck was going to give everybody he raced against 10 lengths because he was on alky now. Chuck gives a piped banshee 10 lengths and a stock Kawi 450 lines up right beside Chuck. The flagman drops his arms and they take off and at the end of the race (1/8 mile) the Kawi was still riding right beside him. Pitiful!
  17. Had a 4mil dune port on stock cylinders and now I have a 421 cub with a cleanup port from Kevin at HJR. Great power from both setups! Fast turn around, great customer service, and great results. I would suggest Kevin to anyone. Not knocking Jeff at FAST because I haven't heard anything but good about him.
  18. Twister top end Cheap
  19. Care to video this race so we can see it?
  20. Well damn. Lol!
  21. 28 pwks
  22. Great idea!
