camatv
    10
Everything posted by camatv
  1. umm have you ever thought about maybe trying to call twister and see what they say????? if you can try to do a PV cylinder. even if they try and talk you out of it. then also pm bigred as well.
  2. toe up from da flo up
  3. another one of these posts??
  4. read the jetting guide. read the needle chart. figure it out. no single "jet" is going to be perfect in your motor AND the motor right next to you. jet motors to what they want . the needle "range" is similar to the jet's "range". you need a differnt main for this and a differnt slow jet for that. needles are similar. usually i jet to the needle thats installed and if it doesnt like the mian choices i have OR the slow choices i have then the needle needs changed. most of the time the needle is a very fine tune adjstment IF the needle is in the close range to what the motor wants..
  5. ugggh that thread is such BS> ceramics wont take a shock like a piston firing. thats also cover'd in some threads where peeps have tried ceramic in everything.. and then had dust through out their motor's/.. roller bearings are excellent IF you dont buy cheap ass junk ass chinese shit and se them up corectley.
  6. you need a full transmission update.. pm me for details. all the other stuff is a baindaide that wont last very long..
  7. its called fabrication if it was easy everyone would do it.
  8. 35 dolla make you holla
  9. hyd supply store ask for viton take an old one in with you and they will match it up. probably cost about 2-3 each if that.
  10. use pressure washer to blast off the dirt. clean with chrome polish. those pipes up there are cover'd in baked on dirt i dont think that was rust.. i have some actual rusty as all get out pipes! might have to try that copper cleaner?
  11. buy the toomey jet kit. install their needles and try 290- 330 mains.
  12. mix the corrct oil if it dosent SAY ON THE BOTTLE mixes with alcohol methanol DONT run it. redline oil does. klotz supertechniplate does and those are the only 2 i would or will run. drill out your stock cap if your using that. need plenty of air capacity to refresh the tank..
  13. sst's wont fall off as hard on top like the t-5's BUT they dont have that t5 sound
  14. oh dude the vforce are bad ass. you should just send me those junk ass boyesen's!!
  15. ha h a hah haaaaaaaaaaaaaa
  16. google takes more than an hour?
  17. dang i want a tig with pulse..
  18. mild sauce from taco johns with some bean burritos is awesome
  19. now THAT is a pump shaft assembly that i would think would work well.. after all the billet failure's and issues i had gone back to completely stock pump parts.. this seems very nice and an actual upgrade.
  20. sounds scarry. yank the cover and take pics!!
  21. you guys know that stuff will fit up under the tank right? then you dont have that congloberation of bullshit all over the place... you can even make a mount and put the cdi right behind the tank and that also cleans it up a lot. i built one a LONG time ago for a drag bike then i recently built one out of stainless strap for my wife's bike.
  22. i dont grease the hell out of my carriers. . there are other things you can do twin row bearing would be more than adequate/ overkill for your "conversion"
  23. i bout 2 states fer muh bunchee and is stizz no spark what the fuzz is wrong iss goes 100 bucks likes now 200 and in 200o you kun harrve is for dess 2 20's in yer hunss what about the dude that went and bought it and turned to key to ON and it started right up? bet his grammar wasnt too shabbadoodie
  24. damn how can i post anything anywhere without seeming like i am following phelps around..
  25. i look at powder like this if i can hit it with a torch and its fine its powder/able
