camp0429
Everything posted by camp0429
  1. What does lost piston mean? Hole in center or?? If your "shop" says they have to bore from 64.25 to 66.00, either shit is totally fugged or you need to find a new shop
  2. First thing is get a Clymers manual
  3. Try adjusting your clutch, set the actuator a little to the left of the case arrow. I've had to do a few this way
  4. I usually set them about 5
  5. That's because the filter is restricting air, all filters will do it to an extent, especially if its dirty. Have you cleaned the filter? No one would advise running that bike (or running anything) with no filter, even just around the block, that's asking for a rebuild real fast
  6. Gets mo powas wid no filter. WOW
  7. Yes they will. I had the same set up on my bike, its now on my wifes bike
  8. ^^ I got a set of these last winter, been running them all year. Impressed with them so far
  9. Very common for reeds/intakes to leak. Do a leakdown
  10. Welcome. Lots of usefull info in these pages and lots of helpfull folks. Thanks for your service
  11. Clutch side oil seal possibly. Do a leakdown test
  12. http://carbondale.craigslist.org/snw/5076021751.html
  13. He's talking about the plastic piece that goes between the main and the bottom of the bowl, it's garbage. The small brass washer under the main on the other hand, will not run worth shit, or at all with out it.
  14. Be cool to do this or that and replace this and that while your in there. It adds up quick
  15. You can get a brand new Hot Rods from most sponsors, $400 trued and welded. I would not trust a previously ran crank unless I knew its history
  16. Did you do a leakdown after installing reeds?
  17. Anytime I drain my coolant for one reason or another then refill to water neck on radiator, it always pukes some the first time you I get in it hard. After that, no more loss. Three or four friends bikes did the same thing
  18. No shit, been around a million years, why fuck with it
  19. Hmm. Never heard of it. We used to just smoke it back in the day, but guess they figured out how to make it better.
  20. I been out of it for a while, the hell is shatter and wax?
  21. BelRay gear saver ftw!
  22. I couldn't make sense of it either
  23. When I was doing some reading on this subject, I came across a "mod" I guess you could say where guys were movin the resevoir to the nose of the frame. They were sayin something about when you go up (or down can't remember) a hill its possible for coolant to get trapped in the vent tube after the resevoir and then when you go down, (or up) hill it drains out and and could make someone think they have an issue when there is nothin wrong. It was somethin along them lines, dont remember where that was at, but it had drawings and measurements and everything
