oldskool
    4
Everything posted by oldskool
  1. I would like to know how this works for you.
  2. Half the knobbies are gone. 200.00 shipped. I dont want to get shitted or nothing
  3. more octane if you have been running 93
  4. Higher compression needs higher octane fuels. More compression means more stress on your crank, but more powa
  5. do you have matching front wheels also?
  6. plug gap .018-.020
  7. thicker base gasket?
  8. Just see how it feels to you. Riders like things different and have different styles. You can always play around with gearing. Sprockets are cheap. If your putt-putting around in 3rd, yeah shift
  9. Just so you know, rod length does not determine stroker crank. A +4 mil crank can have different rods. Rod length does come into play when setting motor up.
  10. Hell, your in luck. We all think we know what we are talking about.
  11. start out in second
  12. Check drain plugs on side of cylinders
  13. You broke it.
  14. Try to go with a mattoon timing plate instead of degree key. Timing plate 45.00. Some aftermarket pipes would be beneficial for performance. Jetting WILL be necessary with these mods
  15. A guy called this morning and told me he had a switch for me, but thanks
  16. 4mil stock cylinders can make plenty enough power for a play bike. You will have to have cylinders ported for extra stroke, you will need you head cut or buy cool head with domes for 4mil. If you assemble yourself, prolly looking at $1400.00 for motor with coolhead (new). A used coolhead and undamaged used domes would be fine.
  17. Was given to you? Well around here nobody will give you anything but a bunch of shit. Read,read, read.
  18. How much for kill/light switch? Is it square plug?
  19. chaw sucks
  20. Dude, you put that bike together and never checked jetting??Does that mean you didn't clean carbs either? Jetting is one of the most important things on these two strokes along with no air leaks. Your lucky it didn't run. Imo, your still going to be too small on pilot. Good luck
  21. Can be either.
  22. I would get oem bearings and gasket for that bike. ESR is the budget guy to go too. The counter balance bearing has to be pressed off/on. ESR also has new cases for the 250r (not oem)
