oldskool
    4
Everything posted by oldskool
  1. well, prolly shouldn't replace anything except plugs, then do some checking of electrical parts. start with grounds. It could be a number of things. Everything but cdi can be tested. A service manual wiil have all specs and procedures
  2. Try going up on pilot and let engine warm up before making adjustments
  3. Just give it some cure time. Is being anxious worth having to open it again?
  4. Will the rod move any, up down side to side?
  5. Damn Matt, that thing is scary fast.
  6. Needle adjustment? Did it just start doing this?
  7. think he saying swap cdi with a known good one.
  8. ESR sells new cases (not oem) Man if you really like the bike, that's cool. I've been down the road with these bikes and they are just not worth it imo. Good luck anyhow. A 250r is like a fat chick Fun to ride But you don't want anybody to see you ridin it
  9. I thought it was going to be about somebody's hat or shirt didn't fit
  10. Hit surfrjag up. He's in moyock. Where is hubert
  11. You want a gasket at the base of cylinders unless you have something very different going on.
  12. Brother, the very first thing you need is a service manual. There's a very good bottom end walk through in the technical section i think.
  13. You always need to do a leakdown test to make sure you have no leaks. The intakes are notorious for leaking air. 93 octane will be fine in your motor. The 300 main sounds borderline for a ported 4 mil. I would go up on main after no leaks are confirmed. Also check floats and adjust, could be running out of fuel up top. The lagging on bottom may be in the needle or air screw. Need to start out with needle in middle clip, air screw at 1.5 turns out from lightly seated all the way in. From here you will make adjustments. Need to know what pilot jets you have
  14. Lens cap should twist off
  15. Pics of mole big as a rat
  16. ^^that's correct. Two screws to each slide
  17. Remove carb top and slide, disconnect cable. Take slide off of cable and spring. The needle will dump out in your hand. It has a clip in one of the five notches on needle. Moving the clip up will cause leaner condition, moving clip down will richen.
  18. With stock carbs, bowls are specific also. Cannot interchange. Just so you know.
  19. Great seller, fast shipping and good communication. Even threw in some clues, gotta love free clues.
  20. New to the game???? Oh, new to the BHQ game
  21. Ford or Chevy. Which is best?
  22. I just want to know, did you shit yourself when kill switch didn't work for you?
