oldskool
    4
Everything posted by oldskool
  1. Comical name. Can you see the numbers on top of pistons you have? May have to clean them a little to read numbers
  2. Bushings, bearings in swingarm
  3. I doubt you do a ground up build buying one part at a time with a 4mil engine for less than 6500 add a lot of bling and you looking a 9k
  4. Big mouth air intake
  5. There's a member on here that will make you a custom harness. He has different ones, this way you don't have all the wires and plugs that would go to tors, ect. that you don't need Kompulsive Concepts
  6. Front brakes Master cylinder with lever Line to block Splitter block Steel tubes(2 left and right) Circlups (2) Rubber line(2) Calipers (2) Pads Fluid
  7. A year is to far away anyhows. Damn, long ride from east coast.
  8. We will only buy clues. Not paying for questions
  9. Good deal! Free bump
  10. PLAN, PLAN, PLAN or you will be buying stuff twice. You will find lots of nice used parts in for sale section, just keep an eye out for parts you need. Used oem ignition parts are best for your buck. A new yamaha stator is around 425.00.
  11. Bought some very nice pipes from this guy. I was furnished with plenty of good pics, had great communication. The pipes were packaged well and shipping was fast.
  12. Are post on this site just as reliable as other sites??? You got something against gays? FFS ROLMFAO
  13. I knew that
  14. check ground(clean) all connections(clean) ohm plug boots or replace, cut about a 1/4 inch of plug wire where wire goes in boot to expose some fresh wire. check pick-up coil gap(.019) set plugs to the same gap. clean flywheel. some things you can try
  15. If you are serious, Think a good carb cleaning should be in your near future
  16. Wow, wish I could ride the china wall Do you go WOT all the way to the top
  17. 110,000 acres???? How tall are those dunes in the pics?
  18. So lets bash the guy for being busy.
  19. Very good seller, He was flexible to work with in my case. No problems with communication, answered any questions I had. Shipping was fast and motor was packaged extremely well without a billion foam peanuts and chips
  20. Klotz 32:1 with 110 octane or MAYBE a mix of 93/110
  21. Damn, let that one slip away
  22. 8 doubleAA (12 volts) batteries will run your led strips
  23. I would tighten that plug gap up to about .020 with br8's. Generally run plug gap and pick up gap the same
  24. Also needs air. I would clean carbs and set floats. After bike has been sitting with petcock on for a while, remove plugs and kick it over and see if gas comes out of the plug holes. Your floats could be allowing your cylinders to flood. Also clean air filter.
