Rage_kage
    2
Rage_kage last won the day on May 5 2015
Rage_kage had the most liked content!
1 Follower
About Rage_kage
  • Birthday 06/17/1992
    PA
    1998, PT Mids, 19cc domes, redline trail ported cyl, stock bore, stock stroke, 28mm flatslide mikuni's, carbon tech lt reeds, charriot intake, oversized rad, timining advance +4*, modified shift shaft from FAST. alba lt a-arms, Fox podium X1 front shocks; dual rate with zps springs, -1 roundhouse, +4 +6 rear axle, stock revalved rear shock, yfz450 brakes up front, ATV four play soft bars, +0+1 lsr steering stem, Labtech steering stabilizer Suspension Modification and service was through Maul Tech ATV STI beadlocks wrapped in GBC XC master rubber full fenders FTW.
Recent Profile Visitors
2,141 profile views
Rage_kage's Achievements
HQ Soldier
HQ Soldier (2/5)
75
  1. I have a stock stroke crank recently rebuilt & welded and trued by sleeper06, I never got to run it, mainly kept it as a back up for the race season. Keyways are in good shape. $275 obo, Buyer pays shipping & PayPal fees Sent from my XT1585 using Tapatalk
  2. Cable sold Intake, carbs and jet kits still adviliable. Sent from my XT1585 using Tapatalk
  3. Pm me for cash price Sent from my XT1585 using Tapatalk
  4. Not sure to be honest. I ran it with a chariot throttle and those 28mm mikuni's and didn't have a issue Sent from my XT1585 using Tapatalk
  5. (2) Mikuni TM28 flatslide, smooth bore carbs. $175 (I will put what ever main/pilot combination in that you want as a start at) Terry cable braided stainless dual gasser cable, used once. $60 shipped Chariot 26-30mm intake with built in cross over, boots are in like new condition. No cracks or dry rot. $120 shipped Mikuni jet kit, 4/042 style mains. Vm22/210 style pilots. Will even include ultra cool cases $200 shipped. Sent from my XT1585 using Tapatalk
  6. I just held 7 psi for 30 minutes... Sent from my phone
  7. I get water everywhere lol, sometimes in the carbs, some times in the stator cover Sent from my phone
  8. I should take stock in NGK, so far I've changed them 10+ times this summer before every race, and mid race if I end up sucking water at a creek section... Sent from my phone
  9. Always a Debbie downer... But your probably right Sent from my phone
  10. Brand new oem coil, brand new oem plug caps where put on it. Problem didn't change. Sent from my phone
  11. I don't run stock carbs, and the problem doesn't move when I switch the plug wire Sent from my phone
  12. I'm having some problems with my electrical system I think, if I push the throttle smooth and slow it will fire on both cylinders, if I stab the throttle the left cylinder cuts out and the right side screams. Starts fine, idles fine, rev's in neutral fine I synced my carbs properly. Pickup gap is set at .15 My electrical readings where: Stator 17.7 ohms - ignition coil 115.3 ohms - pickup coil .40 ohms - lighting coil Coil .50 ohms - primary 25500 ohms - secondary Specs from hq page Stator 13.7-20.5 ohms - ignition coil 94-140 ohms pickup coil .26-3.8 - lighting coil Coil .28-.38 ohms - primary coil 4700-7100 ohms - secondary coil Changed the coil and the problem is still present, I was hoping someone would recognize this problem and maybe point me in the right direction weather it's a cdi going out, stator failing under load, bad pickup coil Sent from my phone
  13. Yeah, being in Australia kinda put alittle limitation on things...but both will work, I just wanted to chime in for a company not to many people know about Sent from my phone
  14. They use a oem reed cage, I think $94 usd did both cylinders, very nice people to talk to Sent from my phone
  15. ISO 2 into 1 intake WITH a stock airbox adapter (trinity) and some sort of fuel metering device to help feed my hungry beast. intake doesn't have to be trinity, just mainly looking for the airbox adapter with a 2 into 1 intake of any brand. shoot me a pm if you have something of interest.
