oldskool
    4
Everything posted by oldskool
  1. Do the hubs accept brakes
  2. Will someone be there to show me when and where I can race since I have a slow bike. FFS
  3. Do you have rubber boot holding cable in adjustment screw on top of carb?
  4. Did you perform a leakdown test after rebuild? This is a must do test.
  5. Good luck, Hope you get back into if it works for you. You made the coolest covers out there. Thanks!
  6. Fuk it, I'm not going either since Dave put like that.
  7. awesome bike, cant stop looking at it.
  8. When you say slide screws, I'm guessing you have tors delete kit on your carbs. When this kit is installed, it is necessary to grind down some material where new idle screws go in order for screw to actually move slide.while looking in carb from breather side, turn screw in to see if slide moves up. Just a thought
  9. Clean carbs, then with slides back in, push/twist throttle and release to see if slides are going all the way back down. Cable could also be sticking. Might try lubing cable
  10. Awesome, especially since I'm in NC
  11. You can also check 250r.net. ESR has new ones.
  12. Looks like the pistons say 65.50. Do the cylinders need a bore that size to clean up? Are the cylinders at 64.00 now?
  13. Nice, like the yellow.
  14. Twittle, ignore me. I misread your post
  15. Says 28mm mikuni flat slide
  16. 27.5/30 pilot Start with 300 main. I think you will end up with 290. This is a starting point, don't assume this is perfect. You need to read your plugs.
  17. Well drop one size at a time and see if it starts getting better 280 being smallest, 300 largest.
  18. ^^^^ that for your stock looking head. I think you will need at least a 421 cub to beat that sphynx, but set-up is just as important as motor
