Vincip92
About Vincip92
  • Birthday 07/18/1992
    New York
    1998 stock banshee
Vincip92's Achievements
  1. No air leaks changed the jets still the same issue changed to the n68a runs amazing can’t believe how much of a difference that made thanks for the help Sent from my iPhone using Tapatalk
  2. Middle Sent from my iPhone using Tapatalk
  3. 135 main 38 slow jet 46jjh needle Sent from my iPhone using Tapatalk
  4. When I get it to run up top it won’t idle ... don’t know why that got cut off Sent from my iPhone using Tapatalk
  5. I bought a set of pwk28’s to go on a stock motor with a k&n air filter and v4 reeds. Before I changed the carbs the bike ran fine no issues with the new carbs I can get it to idle but it bogs up top and when I get it to run up to. Has anyone else had this problem
  6. Bought a banshee bone stock with k&n air cleaner has stock air box came with a set of keihin 28mm pwk carbs but the guy took the jets out to use in his other bike what jets should I use for riding around 1200ft Sent from my iPhone using Tapatalk
  7. ok carb got stuck rode it back turning it on and off any chance the other cylinder got damaged from just being at idle while the other one was stuck open....better?
  8. hit a puddle that was alot deeper than i thought sucked in a little bit of water got it to fire back up kept riding then the right carb got stuck open probably the slide getting stuck but i rode it back to my truck by going coasting down hills in neutral and starting it to get up hills do you think i may have damage the left cylinder from the ride side being at full throttle and the left just being at idle and riding back like that?
  9. Ok thanks
  10. With
  11. A pro design air filter other then that it's bone stock
  12. Didn't come with any just the 2 sets of jets and 2 needles
  13. 270 and 280
  14. Bought a set of t6's and vforce 4 reeds any idea if I can use the jets they sent in the kit or would I have to get different ones carbs are stock and I ride at about 1100 feet
  15. im using my box Sent from my iPhone using Tapatalk
