GrMeyer
Everything posted by GrMeyer
New and Need some jetting advice
GrMeyer replied to adam.bonholtzer's topic in Jetting & Exhaust Forum
Sounds good to me -
Thinking about selling the banshee
GrMeyer replied to pinned247's topic in General Banshee Discussion
you wont get shit for you banshee...the market sucks right now...You might be able to find a straight trade -
I just use the 3 led marker light. I think it was like $8 after my military dis. but its bright as hell and everyone liked it better then the old stock one.
Lite the bitch on fire....fill it full of gas....run some gas out on the ground and watch the bitch smoke!!! FYI..dont use the stock clamps to hold the pods on...go and get some good worm gears that will hold those bitches on.
alot of people I know are running wiseco...I was running wiseco tell i melted a hole in my piston due from a pod filter coming off in the dunes. So I sent my jugs to be ported and now im going to try some Pro-x to see how they work. Im waiting on my crank to get trued and welded and then it will be all back together for some fun...But for jetting You might want to start around 300 and drop it down when you can do some plug chops.
is there are reason why your so High on the jets? What is the pilots set at?
as for the mains I would say you are really close but for the pilots you are rich. I would drop them down to 27.5. But is there any port work done?
Thinking i should jet it by myself?
GrMeyer replied to xXBANSHEE_KILLAXx's topic in Jetting & Exhaust Forum
umm what is the reason why you want to jet up to 290's? -
Pipes and Airflow System (Please Help)
GrMeyer replied to 9FR Productions's topic in Jetting & Exhaust Forum
what kind of K&N intake is it? the one that goes in the box? Pods? filter lid?. Those three will very your jetting. But 300 and 25 pilots are a good starting point -
Q: do you have a buy it now or a reserve price? what gas do you run? How do you like the shocks? Looking to get something for the dunes here in MI, yoursA: The buy it now price is $3,000. please email me at [email protected]. The atv is in perfect condition! Runs like new. You can use any gas you like. I guess you can run some diesel in it
what is the jetting at right now?
Shit I lived in Wyoming and we ran higher then 5280ft. when we hit the top of the rockies mnt. there is no way he can even be close to running that lean of a jet in the bike. the only way I could think is if he was running the 190 he must have the full lid set up on and then tape over the snorkel with a pen hole for air... but all in all we need to know if your running pod filters. with lid, without lid. etc
no need to run High oct with those low numebers!!!! save money on gas for a new top end and a after market head
I look into building suspension first. I can ride longer and take whats thrown at the bike alot easier. But all in all for a trail monster is it tight ass trees or trails where cars can drive down the dirt road? I went from stock bike to whats in my sig and the bike screamed on the trails and dunes. Now i wanted more power to kill. so I ported the jugs for the trail/dunes. Still waiting on crank to get trued and welded and then its back together for trail riding season. I just cant wait to see how much of a diff the porting will be. But knowing what kind of trails you are riding on will help out the builders help you build your bike.
Got a Noss Head and love it...
do you have port work done? and what is your altitude
we need to know what your elevation is and is it a K&N with lid/ without lid. K&N pods. I have fatties running pods with no motor running 290 main jet and 25 pilots. But if it is a bog before the power band then it is more then likely airscrew Q#9:OK, I'm sure it's rich or lean, how do I know what to change? A#9:For a breif recap of the Carb Theory 101 link mentioned earlier; the carb delivers fuel depending on the throttle position: 0 to about 1/8 throttle is controlled by the Pilot jet size, and fine tuned by the airscrews 1/4 to 3/4 throttle is controlled by the needle taper & length, fine tuned by the clip position 3/4 to WOT is controlled by the main jet size Once you know which circuit or circuits are rich or lean, you can begin to dial in the jetting. Q#10:I have a bog or hesitation right off idle, OR an erratic idle, OR a very high or low idle... A#10:Since the problem is between 0 and 1/8 throttle, the pilot/airscrew circuit may be rich or lean, and you may need to also adjust the idle speed screws and check the carb synchronization (see Q#23 & 24). Start by adjusting the airscrews; on each carb turn them in (clockwise; which is richer) a half turn (180 degrees); adjust both airscrews the same amount. If you have the motor idling allow about 20 seconds for the motor to react to the new setting. If the condition gets worse, try going out (counterclockwise; which is leaner) on the airscrews and see if it improves. If going in on the airscrews helps but the problem persists after you turn the airscrews all the way in, or to within a half turn out from seated (don't torque the airscrews! the tip is pointed and overtightening them can cause damage!), try the next size larger pilot jet, and start over with the airscrews 1.5 turns out; tune the airscrews from there to get a clean idle and off-idle response. Conversely, if going out on the airscrews helps but the problem persists after you get to about 3 turns out from seated, try the next size smaller pilot jet and start over with the airscrews 1.5 turns out; tune the airscrews from there to get a clean idle and off-idle response. Once you acheive a clean idle and crisp off-idle response (no bog or hesitation right off idle), you may need to adjust the idle speed up or down by adjusting the idle screws. If airscrew adjustment does not have any affect on the bog or hesitation, and you are certain the problem is below about 1/4 throttle, check the carb sync, make sure the pilots aren't clogged (it only takes a speck of dirt to block the tiny passage), and insure that both airscrews are set the same number of turns out from seated. Be advised that the stock Banshee carbs have a pilot jet that is specific to Banshees; a standard Mikuni pilot jet will not work (see next section for pilot jet details). To verify your pilot/airscrew circuit jetting, start the motor and let it warm up fully; install fresh spark plugs, start it (without using the choke) and let the motor idle for about 10 minutes; pull the plugs and look at the center electrode and base ring; they should be a light chocolate brown color if you're dialed in. As a side note, since the pilot jets are flowing fuel throughout the throttle range (they are solely responsible for mixture at idle to about 1/8 throttle but continue to deliver fuel above 1/8 throttle) changes made to the pilot jet size MAY have an affect on the main jet jetting; if you change pilot jet sizes it's a good idea to verify your mains as well, and to a lesser extent the needle clip position. Q#11:I have a bog or hesitation at about half throttle... A#11:Since the problem is between about 1/4 and 3/4 throttle, your needle clip position may be rich or lean. If you know the jetting in this range is too lean, move the needle clip down one clip position (richer-moving the clip towards the pointy end of the needle). If you're sure it's rich, move the clip up one clip position (leaner-moving the clip towards the blunt end of the needle). If you're not sure if you're rich or lean, try the choke trick; with the motor fully warmed up pop the choke out to the first notch and see if the problem gets better or worse; if better then try going a slot richer on the needles; if worse try going a slot leaner on the needles. Remember to check the carb sync whenever the tops are off the carbs, and don't get the slides reversed; the cutout on the bottom of each slide should face the airbox. Q#12:I have a bog at WOT, OR it revs high & fast with no power at WOT... A#12:Since the problem is at WOT, your main jets may be rich or lean. Since the motor is spinning so fast (usually) when the throttle is pinned, the main jets are the most critical circuit on a Banshee; running too rich or lean on the mains can be extremely hazardous to your motor's health: rapid overheating combined with high RPM's are a recipe for disaster. If you have done mods that affect airflow, start with the manufacturer's recommendations or those shown below to get a ballpark number on your main jet size. Similarly, if the temperature or elevation has changed use the below guidelines to get your mains close (see Q#14 & Q#15). Once you think you are close to the right size on the mains, one method of dialing in the main jets is to start with large mains; if it bogs at WOT drop a size until it revs out clean; if it doesn't bog at WOT go up a size until it does and then drop one size. The bog at WOT is usually an indication that it's rich on the mains, however since running lean is usually worse than being a little rich, the choke trick can be used to make sure before you go leaner on the mains: with the motor warmed up pop the choke out to the first notch; if the bog at WOT gets worse you know you're rich and can safely drop a size on the mains; if it gets better with the choke out you're lean and should start going up on the mains until it bogs at WOT, then drop a size. Another method is doing a plug chop (see Q#33), but since you will be revving the motor out in 6th gear it's best done to verify the mains after you have gone down one size from bogging at WOT as detailed above. When dialing in the mains it's best to err on the side of rich than lean to avoid any damage to your motor (rich symptoms are fairly obvious in the form of decreased performance, and can be remedied before engine failure-lean indications may not be apparent until it's too late). Don't be afraid to go big on the mains, as long as you work your way down to the point that the motor revs out clean all the way to WOT you'll be less inclined to risk damage from running lean.
had the same prob on my bike running 32:1. I was jetted a little rich. Changed jets. kept the same oil mix and started to run the banshee like it was made to run. Now it is clean. And now i just got my jugs ported so everything is apart.
Do you have Fuel? Is the fuel turned on?
before you pull your top off do a compression check and that will help a builder help you on what size of domes you need to be looking for
I run 8 pads and have had great luck with them. I dont think 7 will be enough for you
is there a big reason on why your wanting a drag/dune port? I got an aggressive Dune/play port done from GTravisRacing.com I ride alot of fast trails and dune alot with the mild drag. Just got the jugs back yesterday and waiting for the pistons to come in. all in all the port and polish job came out great. Just waiting to get the back together to see how fun it will be...
I have heard nothing but good things on tcs shocks. But I have elka's on three raptors and they are the dune set up and ride great. As for flat track I couldnt tell you. I have the yfz450 on my banshee and plan on rebuilding here before dune season for revalving and spring. But all in all compression and rebound are the main setups I look for when I get shocks.
just get some 100LL from the airport and call it good...
to tell you the truth im not happy with works and there shit....I would save my money and get some elka's or if your really on a budget then some yfz450 shocks will work just fine on a +2 set up...I have them on love them on my banshee...but anything is better then stock
