jjn56
About jjn56
  • Birthday 04/14/1973
    SW MO
    2002 Blue, LRD Pipes, .060 over wiseco, Carbon Reeds, maxxis razrs
jjn56's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Ill take the clutch pertches if still available, just want the bottom one really
  2. Thanks!
  3. good point
  4. I am mostly a recreational Dune rider but I do go riding in 90 plus degree temps. Do high temps or aggressive riding affect these type of shocks more than coilover shocks?
  5. Anyone running fox floats shocks and how do you like them? How do they compare to say Works or Elkas?
  6. I had a stator test perfectly but when it was mounted the wire burned through and shorted to the case.
  7. So the parking brake switch is removed right. thats exactly what it sounds like is why I ask again, sounds like its stuck open
  8. could be your stator
  9. Definitley inspect all the stator wires for burn marks where its shorting to the case. I just had this happen to me on a used stator I bought. I bought another new stator and it fired right up.
  10. jjn56
    Need 3 stators
    I have one, PM me your address.
  11. Thanks, I'll look at the timing again and report back.
  12. bump, compression left side 128 right side 132
  13. Tried this one already, had this problem about a year ago before I rebuilt my carbs. took the pipes off and no fuel in them, kicked it and nothing came out of the crank. Thanks!
  14. Tried that, still didn't fire, put in about 1/2 a small surenge full, is that to much? not enough maybe?
  15. Adjusted back to zero and tried starter fluid, when I drain the bowls with the fuel on it flows like a river.
