98_shee
Everything posted by 98_shee
  1. 98_shee
    jets and chain
    pm'd ya.
  2. pm'd ya.
  3. I have a stator with stock timing plate, voltage regulator, and a coil. Are you wanting a flywheel puller? I've never shiped to canada so i have no idea how much it will be.
  4. I have a set of pro curcuits for sell if your looking to buy. Pm me if interested.
  5. I have front hubs, right spindal, stator, coil, volage regulator, some odd and end entirnal motor parts, brake hub, pro curciut pipes, im sure i have more pm me if you need anything.
  6. They will work, just make sure they are 12volt.
  7. Im the one that messaged him, he said "is the reason you didn't bid on my bike is because of my typo it really has 220-225 psi". I don't think he realy know much about the bike.
  8. We are going to try and go around the 18 and come home the 22.
  9. Depending on the riding you do. I would go with the t5's.
  10. Did you sand the frame where the regulator grounds?
  11. Pm me with a price if you still have the v2's.
  12. Try bumping the pilot up to a 27.5, and turning the air screw out only 1.5 like stated.
  13. You can get the >oversized< in different colors. Or here's an >aluminium<. Welcome to the HQ :beer: :beer:
  14. huh??
  15. Shift star mod, pancake bearing. Put a 4mill in it and have it ported for the crank. :thumbsup:
  16. They can be put in backwards. The cutaway in the slide should be facing the filter if it isnt then switch the slides around.
  17. Sounds like you need to rebuild, if you can, get another tester and test it again just to be sure. With low compression it will make it hard to start, you may be getting spark. You will have to open the top end up and see what you need. Bore and piston kit around here is $300-$350. You should order a clymers manual it will walk you through everything.
  18. Pods are just open filters no airbox, the cutaway in the slides should face toward the filter.
  19. 98_shee
    stator
    I have one off an '02 pm me if interested.
  20. 120ish for stock. What are your mods and elevation? Be sure to hold the throttle wide open, make sure you have the rite adapter for the tester. And kick it till the needle stops moving.
  21. Did you sync the carbs, Bowls on the rite carbs, and balance tube in place (black tube that goes between the carbs)?
  22. NGK b8es plugs, You should order a clymers manual it will tell you the specs on the electricals. Do you have a compression tester?
  23. Did you change the plugs? You may need to test the coil and other electricals. Do a compression check on it also.
  24. I done the search for you >Tors removal thread click!!<
  25. The 290 and 27.5, 1.5 turns out sounds like a good starting point.
