mignumspeed
1 Follower
Contact Methods
  • Website URL
    http://
  • ICQ
    ROCKWOOD,TN
    87 RED POWDER COAT FRAME WHITE PLASTIC 80 OVER PRO LIGHT PISTONS
mignumspeed's Achievements
  1. great to guy to deal with dont hesitate to deal with him super fast shipper
  2. if i remember correctly i took a brass hammer and pecked mine out when i took it apart just be careful not to booger the threads up!
  3. i have a motofast 2into1 pipe some say its a little better than the dynoport pipe i personally do not know but it runs really good on my bike $135 plus ride its a black pipe with silencer
  4. ive had them in my banshee for two years now and they run great mine are 80'over and the bike is running a motofast 2into1 pipe and i have no complaints i would use them again no question!all i do is trail ride but run them hard.
  5. i think its a personal thing myself i've had a twist on a 250r and now my banshee and i love them,all i do is trail ride and yes sometimes the twist will get you in a bind but overall it probably depends on your seat time and preference.these guys are right the thumb is safer but i cant stand the thumb pump you get from it and i always liked to have something a little different from everybody else which aint always a good thing.
  6. i would like to buy them whats ur price?
  7. i got a dyna port 2into1 i might trade u it sounds like a indy car when it revs up killer sound it runs real good on my woods bike jetting is 27.5 pilot second clip on needle jet and 270 mains at 700ft @sea level
  8. you still got shocks i'm interested give me a shout
  9. i'll take those pipes i sent you a pm!
  10. i recently had this same problem,i set my float to .825 and it still leaked.so i took the bowl off and hooked the fuel line to the carb and turned the gas on and pushed the float up to close the valve and it still leaked.so i took an old float valve a had left over from my rebuild ,put it in and no more leaks,maybe you have the same problem.i bought my rebuild kit from napa,maybe its a cheap kit or something!
  11. where can i get a gear case vent?mine is missing.its the vent under the rear motor mount.
  12. i have an 87 banshee with just a few mods,timing advance,and some 80over namura pistons,will the 34 pj's be to much carb for this bike?
  13. need a good set of ball joints in these if anybody has a set they dont need
  14. i just put new ones in when i rebuilt the carbs.
  15. can anybody help me with my carbs i recently rebuilt them and they both leak out the over flow tubes:they leaked before i rebuilt them.ive checked the float height and its 20mm,ive also ran it lower and it still leaks could there be something missing,i'm sure the bowl screws are tight and the screw that drains the fuel from the bowl is tight,so any help?
