steeler2169
About steeler2169
  • Birthday 12/20/1978
    Milford,OH
steeler2169's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Can you sync carbs with tool while choke is on. I ask this because I just got done with full rebuild and it won't idle with choke off. So I haven't even been able to do proper break in. I wanted to sync carbs first then do break in but right side carb is at 1.5 and left is at 6, is that because I'm trying to sync with choke on.
  2. You might be on to something there one side I didn't get get a warm a fuzzy about being filed down flat. I have the motion pro
  3. I forgot to mention it does get vacuum when I do throttle up a little
  4. Just sprayed around reed cage no change
  5. Not to go off topic but me and you rode together at hasten a few years ago
  6. I'll go try it but I even put a very thin layer of permatex on both sides
  7. I just checked the tube going to the other carb it's not cracked. The choke mid way out is trying to go in by its self
  8. Just did full rebuild and added tors removal. Started to sync carbs at idle with sync tool and left side is at 6 and right side is at 1.5. I've replaced reed pedals also. I need help I'm really getting aggravated
  9. I just cant get the perfect plug.Can you guys look at my mods and tell me where my jetting should be
  10. It maybe just to rich, are there any pics of oil fouled and fuel fouled?
  11. I just rebuilt top end had bored and everything, did proper break in went riding cam back check plugs the looked oil soak. Now could this be from doing alot of idling or do I have a right side crank seal leaking?
  12. Where can I get A good Aftermarket stator cheaper than $401 from Yamaha.One that will last
  13. steeler2169
    Stator
    I'm looking for an OE stator (Used) Please!
  14. I found what it was, this needs to go under the I F**k this up section. I used a screw driver along with the strap and the screw driver poked a nice size gash in the stator.Yeehaa
  15. just pulled plugs and kicked no spark.
