98_shee
Everything posted by 98_shee
  1. You can do it your self the only special tool you will need is a flywheel puller. There is a couple clips that go around the bearings be sure to put them back in and all the bolts on top and bottom of your cases are numbered and you need to tighten them in order a little bit at a time, just keep going over them till they are tight, i normally go over them 3-4 times. If you don't have a clymers manual you should invest in one, it will walk you through everything. And welcome to the HQ!!!! :beer: :beer: If you need any help or get stuck on something pm me and i will be glad to help you.
  2. If you don't think you can sell it around there. You may be better off parting it. The stock parts will be the hardest to get rid of.
  3. Im not a fan of the ebc clutches, had bad expereinces with them. You may be running the wronge oil or a oil that is to heavy. Is the oil designed for wet clutches? If not you need to drain it before you smoke your clutch. Also did you soak the fiber plated before you put it in? Get some oil that is designed for wet clutches if that stuff isnt.
  4. Im running dual 34's, but have a set of 36pwk's on the way.
  5. Will they fit a pro design? Im interested in the 20cc's.
  6. A two into one will give you bottom end. The duals will give you more top end. Do a search, there is lots of posts on it
  7. they are cut so the piston can slide in them. so you don't have to run a spacer plate with the long rod crank.
  8. 98_shee
    wanted
    Hey jt those cages are aftermarket.
  9. I have a set of 18's, if i can find some 20 or 21 that are not cut I will sell them.
  10. 98_shee
    wanted
    No problem man.
  11. I also have one. He does some great work!!!!!!!!!!!
  12. Are you wanting stock reeds? Can you post pix of the bumper?
  13. 98_shee
    wanted
    Pm arfountain he has a few seats not to long ago. He may have most of the other parts you need also.
  14. I have a stock head, if thats what your looking for pm me.
  15. 98_shee
    +4 swinger
    No, you can get one off ebay new for around 110 shiped.
  16. I forgot about that oring. could be that to.
  17. Water pump seal.
  18. Nobody has a set of dome's laying around? I just talked to alba about the chozed performance domes, they said they will not fit a pro design head and its a good idea to stay away from there products because they went out of business.
  19. Are you only interested in pwk's? I have a set of 34pj's i may be getting rid of when my new carbs come in.
  20. Pix of the axle?
  21. 98_shee
    +4 swinger
    I have one that has been in the trade section for a week or two, I just put it on ebay. There's a link in my sig to my ebay stuff. Its a roundhousing though.
  22. Swinger is on ebay. Theres a link in my sig.
  23. You don't need a +4 swinger do you? :biggrin:
