LS1Inferno
Everything posted by LS1Inferno
  1. to do the timing yo need this Rick Stator all you do is pull fly wheel and unbolt the stator and unbolt the coil an dbolt it to this ans set it at +4 and youll be good for 93 Oct. the head is not necessary for port work or carbs. it is just the ease of changint domes to up the compression thus power BUT you need race gas above 160ish PSI. and porting and carbs do not have to go together. BUT if you get a nice dune port then you will want some slightly bigger carbs. instead of a cool head you can just have the stock head milled to up the compression IDK how much i don't remember. that is a BIG savings for a little bit of power. maybe $20-30 at a machine shop. if you ride trails smaller carbs are better for low end. and you can get a trail port. all depends on you type of riding let us know and we can tell you what your best setup would be. ALSO if you dont need it for mud and water you can loose the airbox and get pods and outerwears.
  2. he only has one because you usually only burn up one side when things go fubar. ill take it lol
  3. your jetting sound off whats you elevation?
  4. please tell me you didn't use the same plugs you took out. does it star right back up or take aw while? and only wen hot or cold or both? sounds to me like its loading up with fuel or does it winde up before dieing. if its now both my gues would be electrical. check all ur plugs and cconnector and wiring for melted wires
  5. the only thing ive heard about the fmf gnarlys are they are just a little bit thicker steel than fattys. other than that.. seem the same to me.
  6. the 916s got discontinued when they came out with the aliens. just search for them on ebay.. from what ive also heard is that the headpipes are the same on the 916's as the aliens. just doesnt go into that kickass silence. i got a set on one of my banshee's and they are really mid to topend pipes.. i like them tho.
  7. well if he has stock cylinders and no spacer plate. then just drain the coolant and take off the head. get a caliber and check the bore. and if its got a scroker domes (domes that are recessed a little more hten 2mm then its a stroker if it doesnt have a plate it will have the domes.
  8. Well take off the carbs and intakes and look inside and take pics and get back to us. that wil tell us if its ported. other then that the only thing to do is take the top end off and see what the bore is and if its stroked.
  9. you can leave it at that but that didnt cause it to heat up, whats you jetting?
  10. yeah those 25's are too small for that elevation. try the 27.5 and set the air screw at 1-1/2 turns out and go from there.
  11. well you dont loos the top end if done rtight , and if you do loose some, just change your sprocket. you will have A LOT more power with the stroker shee then stock. and what do you plan on doing with the bike, that justifies how big you go.
  12. everything looks good with the port except you may want a different set of pipes then the fattys.
  13. yeah ive bought bad brand new batteries before and yeah DO NOT charge them on high amprage the first time you will cook the cells, just dont tell walmart that, jsut tell em it dont work
  14. go to ModularFords.com they can tell you anything you need to know. but for me im sticking with my LSx stuff too its ALL interchangable.
  15. if your stock timing then that wasnt detonating. what rating fuel are you using. your jetting could be lean. any detonation caused plugs to back out, also gets hot and melts pistons.
  16. auctually i think the 250 is just a smaller bore and thats it. but yeah my first real atv was a banshee.
  17. do a search for DC conversion there is and enitere HOW TO around here3 somewhere
  18. then yeah you should be good with the big carbs and people who talk bad about PJ's i have nothing wrong with mine. and they are A LOT cheaper the PWK's
  19. well if you go big that big with the carbs you arent going to want the FMF pipes. you need somthing higher up. i have toomeys on mine but im going to get CPI's or somthing because the T-5's are to pipey for me but the big carbs and port are soooo nice
  20. screw the autoparts store. there is a little hydraulic shop on cheyenne and civic center in the area by napa. and ever been to ATV Cycle Sports? if no go there for ANY parts ask for "parts bob" 223-3586
  21. well i HAD two of them i couldnt get em jetted right. and of all thing only one side burnt up on one. i now have one back to stock carbs and the other that is ported had a trinity on it and thats the one that burnt up. now have 34pj's and couldn't be happier.
  22. ok the lightning motor you are after will fit fine the 4.6 , 5.4 amd 6.8 V10 are modular same motor mounts accessory mounts and trans mounts NOTHING 3V will work with the old 2V and you dont gain power putting in a lighter car. you can NOT beat the lighting motor for 750 if you dont want it where is it so i can get it. i had a mustang i was gona put a V10 in cause i knew someone who did it, but it is a TIGHT!!!! fit and i bought a TransAm insted
  23. the length from pivot bolt to the carrier mount is 20"
  24. yeah its bad take the head off and look rings may not be enough. if it happened fast ive just put on piston in one side before lolwithout a bore.
