sleeper06
    20
  1. Leave the 240s do a proper plug chop
  2. Lol no way in hell that dent is gonna pop with compressed air, a lil dent ok I've done a few myself and they took a lot more than 5 psi . The way that metal is rolled over and stretched I'm skeptical. Worth a try just be careful
  3. Looks like gas tank / plastic screw
  4. Sleep adding fuel till it gurgles over then back it down,don't worry about any other part of jetting till you get your mains dialed in, also pc pipes are gonna limit a ported motor.where did you get those? It looks like my earlier hand work but hard to tell
  5. I can do it,if all bearing run outs check out and everything looks good,$50
  6. I found it less time consuming to tune my clutch when I went 300' drags , I could have gotten lucky or had some wheel spin compensating or the bigger RO powered through the clutch better . I would love to do more 300' just nothing around by me
  7. I have weent as far as having arms made out of diffrent materials to reduce centrifugal force and just add weights if needed , my small motor doesn't need much weight if any on most tracks . Multistage is much better option in adjustability and quickness of adjustment. I got my boys r1 pretty spot on in 3 passes on the street
  8. Nice shot good job guys
  9. 280,30 pilot, needle 4 th clip to start. You might need diffrent needles
  10. Spray it into back of carb body
  11. They run good if set up correctly but will cost a lot more to build, just buy a wampus
  12. sleeper06
    Crankshafts
    If you want I'll send you money to ship
  13. Do you have springs on the shift fork shafts , the drums are relief cut to allow you to override the gear your in and bang into the next, without spring tensions on the sliders it will bind
  14. Well jetting Is out if anything your rich,I'm going air leak. I would not ride it anymore till you pressure test it there is pics all over this site about . Needs to hold 6 lbs for 6 mins accept nothing else, or think you know what's wrong with it and burn it down trying to figure it out
  15. That's my issue Brian,I babysit grown men all day , if I'm not there nothing gets done. I was off yesterday for a doc appt 2 of my crew put up two fixtures in a 8 hr day. On the other hand there professionals at hide n seek
  16. That's fine or ship the shit and I'll send it back , prob $40 round trip shipping and gas might be more but either way
  17. sleeper06
    Crankshafts
    What kind of 7 mil , if it bent a rod it's a good chance center section is outta true let me know what you thinking
  18. Unless ur trying to off her I wouldn't take anything there
  19. What was it doing to make you pop the top off it, I would have checked squish . What you had right there can run in the right hands. Most would consider it it a cobbled together. If it were me and planned on building something else later I would deck the cylinders and head for a good seal and put it back together , that look to be wang crank that I wouldn't put a wampus over unless u let me swap rods n bearings and just reuse the webs. Either way it ain't cheap , if your gonna order a cool head from Jeff 22 cc domes won't cut it on a 4 mil for pump need 23.5-24 cc domes if it were my motor I would deck the cylinders about .005 order .025 and .030 base gaskets 24 cc domes and noss head . If u need to clean the cylinders up let me know
  20. I would do both for a diner , tranny is a must a lockout gives you a lot of options for different riding
  21. Is that a wang crank , can't tell from picks, in hine sight you should have let me build you killer , you would be riding not ripping it down
  22. If u can return that crank and get a hot rods or vitos 4 mil long rod it will be your best option I have seen many ducked up wiseco cranks with broken rods separated webs. Maybe they have improved but I boubt it
  23. sleeper06
    Crankshafts
    Top
  24. Did you ever get the rite fuel
  25. If it's detonating that head will move, who cut the head for the 4 mil , what's your squish @, check compression again ,
