What are the specs of the bike,I have personally found those carbs to run big pilots like 55s so i dont think your that far off ,I have also went as low as a 140 main jet in a ported motor .My advise is to start lowering the main one step at a time,leave the pilot ciciut till you get the main dialed in.Once top end is good adjust your midrange with the needle,then touch the pilot circuit for good idle and responce.They take kein long jets(hex)same as pwks.Dial it in for temp now,I usually have to lean one step in the summer months.Remember one thing at a time,too much at once will leave you not knowing what really made a diffrence.If your fouling plugs also check your plug caps and spark,They will def play a role,Ohm out your caps the rite way like a manual shows,you will chase your tale with jetting if your ignition is not up to par
