kxexvxixn
About kxexvxixn
  • Birthday November 3
    Oklahoma
kxexvxixn's Achievements
  1. Can I get some larger pics please to [email protected]
  2. I didn't have time to look through the whole thread while I'm at work, but can someone tell me the exact date that was chosen for this? I saw on the first page either the weekend of the 15th or 22nd. Thanks
  3. Lid is off air box. Thanks for the info..Where's the best place to purchase some jets..?
  4. Can't wait to see it.. Those wheels looks awesome..
  5. Anyone?
  6. Damn it looks really good already..
  7. sorry about that thanks..
  8. Alright guys now that I got it running and broke in last night. I'm looking to see where I should go with my carb jetting. Bike has t5 pipes, adj. timing plate(+4), pro design air filter setup, and a .040 over fordged piston kit. Everything else is stock. I believe the current jetting is stock. Do I need to rejet? If so what would be a good choice..? Thanks Kevin
  9. Well sure enough, swapped stators last night with one of a running banshee, started first kick..now to just break it in and have some fun..Thanks for everyone input..
  10. Well the reason for checking the stator will be because on a 250r my brother had, he would get spark and it would test good, but just wouldn't fire the motor, swapped it with another stator and it fired right up. I'm pretty sure it's either the stator or something in my wiring harness. The tors boxes are still on the bike, but has be over ridden. The reed cages looked good, and have new boysen reeds. Hopefully I will figure something out this evening..
  11. Haven't really tried starting fluid for that reason. Haven't checked the pick up coil gap. Will check that tomorrow, and will also be trying a stator off a running banshee. And yes sure its +4..
  12. Rings are installed properly. Compression when I checked it earlier was 120-130 on both sides.
  13. That sucks man, but mine won't start at all..
  14. Ok they're in correct then. Anyone else have any ideas? I tried my cdi box on another running banshee and it started with my box so that should eliminate that as being an issue.
  15. I believe I have them installed correctly. But just to make sure which way should the half moon cut at the bottom of the slide be facing? Towards to motor or towards the air box?
