Everything posted by BellicoseBanshee
How old is the fuel? If it is more than a few months old, put new fuel in, new properly gapped plugs, clean the filter, and clean the carburetors, one at a time, really good (disassemble, clean, and reassemble). That will give you a better starting point.
Any good grade of pre-mix two stroke oil and wet-clutch gear oil will be just fine, similar to the 250Rs you have had in the past. If you are looking for a particular brand, I run Maxima Super M pre-mix (32:1) and Maxima MTL for the gears. You will find many opinions concerning oil mixture and brands. It is kind of like asking which beer does everyone drink! :beer:
Lets say you are mixing 1 gallon of fuel, 128.00 oz. At 32:1, you need 4.00 ounces of oil per gallon. At 33:1, you need 3.87 ounces of oil per gallon. 4.00 - 3.87 = 0.13 oz. Lets calculate percent difference: [E2-E1/(E2+E1)/2]x100% = [4.00-3.87/(4.00+3.87)/2]x100% = 3.30% A 3.30% difference in the two oil ratios is not going to make that much of a difference. As mentioned above, unless I take the time to measure exactly 32:1 on my ratio cup and then swirl some fuel in the cup to get all the oil mixed with fuel, there is a good chance that my mixture is off 3.30% any given day.
Need help with this math
BellicoseBanshee replied to Bansh-eman's topic in General Banshee Discussion
The key here is order of operations: () first, then X and /, then + and - . And also remember (a/B)/(c/d) is equivalent to (a/B) x (d/c). Looks like you might have those down. :thumbsup: -
That is a good idea..... .....and it just might work.
I agree, I would pull the cover and get it out. Wouldn't want to take the chance of little pieces jamming into things and causing problems. Who knows, maybe nothing would happen, but I think it is worth the time to get it out. My $0.02.
I am not sure that is the best advice..... :ermm: For twenty dollars or so, you can buy a few sets of jets and know exactly what you are installing each time you make a change. I am not trying to give you a hard time, it just doesn't make sense to me.
I concur. Just remember, do not change your oil ratio to troubleshoot a jetting issue. Plug Chop
It would be cool to have treaded posts or nut-plates along the bottom centerline of the tank. The wire harness, cables, etc. could be clamped to the bottom of the tank. Just a thought. :geek: Might make it more of a hassle to pull the tank though.
So does it have real 300s or guestimate 300s? I don't think I have ever heard of anyone drilling out $3.00 jets!
Everyone has his or her own style and taste, but those fenders just do not look right. At least there is another place for a lunch box or a thermos now. And I agree about the fuel mileage, I do not see that happening. Maybe he was drafting! NOT!
Question for you guys
BellicoseBanshee replied to TeamRealtreeHD's topic in Banshee Repairs and Mods
Uh oh........time for dajogejr to post up that can of worms!! :yes: You are going to get a thousand different answers from a thousand members. If you do a search, you will find that question answered many times. As for me, I run Maxima Super M Premix (Maxima makes Super M Injector also) in my banshee, mixed 32:1 with 93 octane pump gas. Unless your timing and/or compression requires high octane, you are wasting money buying 112. That's just my $0.02. -
so guys...whats next for me?
BellicoseBanshee replied to Skithis's topic in Banshee Repairs and Mods
As said, I would talk to an engine builder about a port job and work around that. -
Back in the day, I quite often rode my LT250R in the snow, but mostly groomed or semi-groomed trails and frozen lakes. I used Pro-Wedge II tires and didn't have too much trouble. Three-wheelers, 250Rs, and Quadracers were pretty popular back then, so I cannot speak from experience as far as the Banshee is concerned.
If it is like this one, it should cover both of them: LT230 Clymer Manual http://www.clymer.com/images/BookImages/PRD_430.jpg
Don't know if it is the best, but here you go: Carburetor Parts Warehouse
Your fuel requirements should be based on compression and/or timing. If you can run pump 93, use it and concentrate on dialing in your jetting. You will benefit more from precise jetting than expensive fuel, no pretty smell though. My $0.02.
Yeah, most people laugh when I mention or whip out safety wire. <--- I guess it is not hard to figure out why I like safety wire. :geek:
I don't think it is hard. If you have done a two stroke before, then you should have no problems. Just read through the manual and follow the steps. I think BigRed350X has a case splitting guide, I will try and find it. Here it is: Splitting the Cases Hope that helps! :smile:
Yeah, you will be very happy if you get your cylinders done before installing that crank, well worth the money! :thumbsup:
The airbox lid holds the stock filter cage in place, so you cannot just remove the lid and run it. You will either need to buy the filter/adapter plate assembly or use self-tapping screws to hold the stock cage to the airbox. The reason dajogejr is telling you to spend a few bucks on some plugs is simple: spark plugs and plug chop = not much money replacing the top end because you think it is fine = much money
Sorry, I should have been more specific, it is an aftermarket head (modquad). EDIT: Referring to my first post, my friend has the aftermarket modquad head. Sorry for the confusion, it's early! :turned:
I am drawing a blank on the name, but you could pick up a couple of screws that have a hole in the head and use 0.020 safety wire to help secure the screws. That might be overkill, though. :ermm: EDIT: Of course, the safety wire chafing the carbs may not be the best.
A friend had the same problem, blew the coolant reservoir bottle cap and coolant soaked the back of the bike. Pulled the head off and found a faulty O-ring. That is the only experience I have with your problem.
98 Banshee 377cc
BellicoseBanshee replied to unstopable_baller24's topic in General Banshee Discussion
Generally speaking, that is true. For that kind of money, I would have two!! :biggrin:
