IROOST1
Everything posted by IROOST1
  1. Anyone???
  2. Is that for the whole carb or just the bowl? Dave
  3. If I were you, I would just part it and take the $ to buy a decent one. These things cost a lot of money and some of those fixes are not too bad but if the head is dinged up, there could be some major damage.
  4. needed: pj float boal, its for 34 mm but any might work?
  5. fuel was about half full but i am gonna get some gas in the mornin. I put the new 25 pilots in and new stock pilot air screws. Once i get some more gas, i will try it out.
  6. I already double checked the slides and a change the carb peices one at a time so i dont mix up parts. The pilots hopefully will fix it.
  7. The intakes are all new with heavy duty clamps and all new hoses. I dont think there is a leak. I will try the 25 pilots and hope for the best, any other suggestions..................
  8. Is a 30 pilot too big? I have new 25's that i can put in.
  9. yep, the tube is connected, thats the first thing i checked when it wouldnt run right. then today, i put new airscrews and springs in and played with the settings. I couldnt even get it to start. Im gonna try some fresh gas and if that doesnt work, im gonna go back to my original settings. The plugs are brand new even. I have no idea why the hell this thing is so finicky.
  10. Bills pipes and silencers(repacked) Stock Carbs with tor removal kit Cylinders bored, honed and chamfered by Eric Gorr(.020 over) Wiseco Prolite Pistons Pro flow aluminum airbox adapter with K/N filter, Airbox Lid Removed Aluminum Boost bottle I had it running good and then i took my 280 mains out and put in 290's cause the plugs were a little light. Why would it run good then just changing the mains, it will barely start, or run. Now 290 mains 30 pilots 1 out airscrew 3rd clip, stock needle Its about 40 degrees out but i will be running it when its about 20.
  11. 85 honda fl350 ?dont know if this counts? 02 blaster brand new then 01 banshee also now 95 banshee i kept the dirtbikes out or it would be a long list
  12. How about if i just use the yfz shock on the banshee. Wouldnt it just sit a little higher than with the shorter shock. Well, ill find out, got a brand new takeoff with a new shock cover, 60 shipped. So we'll see how a full yfz front and yfz shock rear does???
  13. For x-mas, i got a powder coat kit and a blast cabinet. So i just ordered the crushed glass to strip everything and all the pc supplies and several lbs of reflex blue powder. Im gonna do most of my banshee yamaha reflex blue but what color frame should i do. I was thinking a high gloss black. I have to paint the frame since the oven i will be using wont fit a frame in. Gloss black Flat Black Candy red??? Oh yeah, it wil be running blue fenders and black tank and rad cover.
  14. I dont know if anyone has tried to fit a yfz450 swingarm, shock, and linkage on a banshee. I am going to give it a shot. Just wondering if anyone has tips, tricks, or experience with this. IROOST1
  15. carb rebuild kits from dennis kirk, 15$ each carb. Its a good deal. I had the same problem, just put in new needle seats.
  16. Im gettin a bog just off idle, it doesnt die. It just lopes then takes off. Only when riding it too. Im at 280 mains, 1.5 out air screw, ? pilots, third clip stock needle. 1999 Yamaha Banshee w/ title 2001 Motor Bills pipes and silencers(repacked) Stock Carbs with tor removal kit Cylinders bored, honed and chamfered by Eric Gorr(.020 over) Wiseco Prolite Pistons New welded crank Pro flow aluminum airbox adapter with K/N filter Aluminum Boost bottle w/ brand new manifolds AIRBOX LID OFF ILLINOIS, its cold out ANY SUGGESTIONS???
  17. OK, i tried three different banshee masters and i even rebuilt the one, and none of them would build pressure no matter how many times and ways i bled it. So I got a front master off ebay from a new yz250. Since my yz does stoppies easily, i figured it would work. And it did. Now the brakes are rock hard and i didnt even bleed them when i switched the master. So if you cant get your front brakes to work right, get a new, stronger master!!! PS, i have three crappy masters for sale
  18. Im tryin to save up some cash so maybe after x-mas???
  19. \Yeah, i know that area well. Im right off north and county farm, about 10 min from wheaton. Let me know, im always looking for new places to ride and people to go ridin with.
  20. I cant believe no one has posted. I have an extra but its not clean or anything, 20 shipped. But you can try ebay, they are always on there for about 10 + shipping.
  21. is that 75 each or for the set?
  22. What type of welder do you use to get that nice of weld?????
  23. I wouldnt put on glasspaks unless you like cops. You will be pulled over all the time. I wouldnt pay the money for the flowmasters either. Magnaflow stainless steel is the way to go. Do it right the first time. My 05 dakota has a full custom polished stainless system with a 31 inch long round magnaflow. A a great 3.5 inch tip, its the perfect rumble and when i step on it it hauls ass. Only cost 200 bucks too.
  24. I have one im gonna be sellin, 99' $2500, im in carol stream. Im currently jetting it and getting it tuned for the cold weather. pm me if interested/pics
  25. how much for the seat cover? is it in good condition?
