IROOST1
Everything posted by IROOST1
  1. I am thinking about parting my banshee. would it be better to sell the motor parts individually and then sell the rolling chassis. Or should i wait to find a buyer for the whole thing. Or part every individual piece(dont want to do, takes too long). Anyone have experience? what should i expect to get?
  2. I will take some new pics this weekend after i wash it.
  3. I found one, it needs some paint and be cleaned a bit. The thing with the two screw holes correct? I can ship it to you, i will have to find out if i can ship it first class mail cheap since its thicker than 1/4 inch. Let me know
  4. no one has a swingarm seal that goes in the cup???
  5. do you have some pics? >[email protected]
  6. Starts first to second kick, runs good. http://i193.photobucket.com/albums/z208/ir..._0504KI0005.jpg http://i193.photobucket.com/albums/z208/ir..._0504KI0004.jpg http://i193.photobucket.com/albums/z208/ir..._0504KI0006.jpg 1999 Yamaha Banshee with clear illinois title 2001 Motor Fresh Rebuild with new crank trued and welded Fresh Cylinders are .020 over by Eric Gorr Stock Porting New Wiseco Pro Lite Pistons Stock Head NGK BR8ES Plugs with New NGK Plug caps New Intake Manifolds Aluminum Boost Bottle TORS Removed with Motion Pro Throttle Screws K&N Filter with Filtercharger and Pro Flow Aluminum Airbox Adaptor BILLS Pipes and silencers (flat black) Gold DID Chain DG Aluminum Nerf Bars DG Aluminum front bumper Renthal Barpad New ProTaper Grips YFZ 450 Front Master with polished aluminum lever New Brake Pads, cleaned and greased brake components Aluminum Quick Adjust Clutch Lever Douglas Red Label Front Rims(85% tread) ITP polished aluminum rear rims with like new maxxis razr mx's(95% tread) New Seat Cover Billet E-Brake Blockoff Shockwears shock covers All suspension/chassis pieces cleaned and greased New A arm bushings Rebuilt kickstarter New Radiator hoses I will also include extra main jets, pilots, needles. I will also include a beat up set of white fenders. And your choice of black or red tank cover. I may also swap the front rims for matching ITP rims and like new maxxis razr mx's. LOCATED IN 60188 Zip code Any questions, ask... OH CRAP, almost forgot, $2600.
  7. Yeah, as long as its fine when the crank was out your fine. I had the same thing happen on the last two motors i built. Once the flywheel and clutch is installed, it seems like its not spinning right. But its fine, just has some tension on it.
  8. i need the yamaha blue plastics. thanks
  9. I checked the orange wire with a check light and that worked. I couldnt check it with the multimeter since the batteries were dead. So i swapped out the coil. It started after that. Thanks guys.
  10. The tors are removed. I will check the resistance when i get a chance. I have had jetting and a air leak problem before but those are taken care of. The current coil i got used and put new ngk caps on it. I have two others if it is bad. But i dont have another stator if its that. I checked the wires and dont see anything pulled or stripped. I just done get why it would be fine then just fart out.
  11. anything ngk, nothing else. b8es, br8es, br8eg if you want to fork out the cash. or br9es is a hotter plug.
  12. every time, it seems like this thing is haunted. this morning, it took 2 kicks to ride up to my truck to go out to the track, but it was sitting for 2 weeks since the last time i started it. otherwise, it would start on the first kick. I get to the track, starts right up. runs fine all day except my throttle stuck open in one corner, but i got it to pop back down. when i got home, i unloaded it from the truck and started it to ride it back to put it away. and it sounded like it was only running on one cylinder. so i changed out the plugs, now it wont start at all. and it has no spark, in either cylinder. and yes the handlebar switch is on, the key switch is removed. wtf. what the hell can be wrong. i checked all the wires and the coil. nothing is loose. i dont understand it. this thing seems like its haunted because it nevers want to stay running good.
  13. have you tried going leaner, sometimes, too rich will bog also. And you said the plug was dark so youre probably going the wrong way.
  14. I quess im not the only one. I have my pal remington 1187 12g close to me every night. Damn the person who mess's with my stuff.
  15. i saw some yamabond at the local farm and fleet
  16. IROOST1
    wtb quad
    Its spring, its gonna be hard to find one even for 1500.. Everyone has the itch now
  17. IROOST1
    need tires
    I have a full set of the stock 400's tires, good tread, no punctures, what are they worth to you?
  18. i just need one swingarm seal that goes in the cap thing. In working condition. I just dont feel like going to yamaha because the retards always screw something up. I think it would fit in an envelope.
  19. it says its too big, how can i make the file size smaller?
  20. sorry, i dont have it hosted. Just attached to an email off my hard drive.
  21. your email came back mailer demon, could not deliver. Anyone else know how to post pics, i need an email.
  22. IROOST1
    coolhead domes
    I've got some 20s I'll trade you if you pay shipping for both. It'll keep your cost down, let me know if you're interested. No thanks, im keeping mine. I have some 19cc for $45.00 shipped Sorry, the price is a little too high. thanks
  23. nah, its paint on or roll on. No need for heat.
  24. yeah, real tough. Its bedliner so its got to be. If someone can give me there email, ill send them a pic to post up. I have no idea how to post it.
