FasterThanU90
About FasterThanU90
  • Birthday 01/30/1989
Contact Methods
    Needles on the River
  • Interests
    all extreme sports expcially Wakeboarding,Surfing,Rding my Sector9,shootin shit then blowin it up,Glamis,BAnshees and anything with a motor
    4mil cub
FasterThanU90's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. some brands of starting fluid have upper cylinder lubricants like GUMOUT. Yamaha sells a product called Fogging Oil and engines can run on that alone..
  2. every seems to agree and disagree .. on brand new engines i have used a tiny bit of carb spray through the plug hole to get the carbs primed. A one second spray really aint shit. Thats a very small amount of atomized liquid. ..It is strong and yes it can strip off oil from what it contacts. i have never had a problem..before assembly i have coated everything with oil like the piston, piston pin, crank shaft ends and cylinder wall. Im confident everything is lubricated. Some have used it with causing no damage at all and some have had bad experience with it.. read the directions on the can. All my bikes r on alky. On a cold or Hell even cool day sometimes it will not start without it. I have never had a prob. I have herd stories of peps just blasting it in there and washing down the cylinder and cause some scaring. But that has never happened to me Skip Zero
  3. If you do not want to have electrical issues which Banshee's are notorious for because of all of the safety equipment then I have the simplist wiring system available and anyone can make it from yours. First you have to not want any of the safety stuff or the light, Although adding the light isn't much more of a problem. This is all you need to make it run. First loose the tors system and all wires. Loose the voltage regulator because they fail all of the time and if you still want to run lights, you cvan get brighter ones. For the simplist wiring system eliminate all of these items in the second picture. Save the Stator and all the wires in the connector. Plug the Stator connector to the CDI conector and eliminate all of the other wires. You only need to plug in the black and orange wire to the coil and then run another ground wire to the coil mount(make sure to sand it) and another to one of the nuts on the head, because the motor is not always grounded, especiallt if it has been painted and the mounts were not sanded. You have to have a Tether switch so eliminate the kill switch and wire the tether to the coil. all of the wires coming out of the CDI are for the safety features mainly the R/B,B/W and B. again the only wires you need are the orange and black ground wire. Here is a picture of what it should look like. VERY simple compared to a stock one and it you still want to run the lights, just plug the light wire into the Stator connector and they will work, but they do rob power. from speed demon at atvdragracers.com http://www.atvdragracers.com/forum/two-stroke-technical/1225-banshee-wiring-diagram.html
  4. what do your plug caps look like are they rusted out on the inside? Can you get an OHM reading on them?
  5. yes it should run with it unplugged.. also you could unplug it from the coil at the black wire
  6. Im happy with the Boyessen pro power reeds on my stock cyl bike.. i have v force 3 on my 4 mil cub both great choices but the Boyesen is cheaper just buying the petals not the whole cage.. its worth the value.
  7. Thats what he said dude and i know how the switch works
  8. Not all the time but sometimes yes a little bit is better than kicking it 50 times with no gas and oil getting to the top end.. a lot of mechanics use it to diagnose mechanical problems.
  9. He is somehow getting no continuity to ground in the off position occasionally. Thats not wierd ?
  10. do you have issues or something youre very rude.. fuck your hypothesis bro.. if you cant understand loosening plugs to spray starting fluid in the cylinder then you are dumb as fuck.. Ive rebuilt brand new engines that are dry and need a little boost to get the pressure differences going through the carbs and cylinders
