SAVAGE420
    19
Everything posted by SAVAGE420
  1. Go hand tight first, then 10, 15 then 20 in a sequence all times of course.
  2. HAHA mike you drunkin hillbilly. Yeah, where the pics at?
  3. Screw them all down in a criss cross pattern till they all JUST bottom out on the pressure plate. Then torque them all to 8 ft lbs in a criss cross pattern. Don't lock tight them though.
  4. Make sure to have it set correct, then use the nut and keep it tight with BLUE lock tight also
  5. I could probably get you close. Around a 300-320 and a 27.5 pilot. But have a look through here first. I bet theres a lot of people with the same set up and elevation as you and what not. http://bansheehq.com/forums/index.php?showtopic=99361 << Thats sticked at the top by the way. Always a good read also. http://www.dfn.com/benkaren/jetfaq.html Also dont hurt to do after http://www.dfn.com/benkaren/plugchop.html
  6. I have the same intakes and VF3 set up. I cut the shit off the back and smoothed it all out. works fine like that. Let me know how it goes
  7. 3 grunts is fine, but technically its 59 ft lbs. Then use your lock washer behind it and bend the tabs up.
  8. http://s102.photobucket.com/albums/m88/HillKiller/ATV/?action=view&current=Bansheebackflip.flv Yikes
  9. http://i27.photobucket.com/albums/c164/savage_420/Funny/HackSaw-1.jpg http://i27.photobucket.com/albums/c164/savage_420/Funny/welder.jpg
  10. Been using Amsoil Interceptor at 50:1 mixed with 100LL in lots of shit for a good long while.
  11. Mod quad makes a windowed cover.
  12. Yeah thats creative for sure.
  13. Slacker Candidate 1 Slacker In Training 50 Graduate Slacker 100 Pizza & Beer Lover 250 LaZBoy Test Pilot 500 Serta Mattress Tester 750 Drives With Eyes Closed 1000 Jack Daniel's Tester 1250 Lost In Space 1500 Sleeps Upside Down 1750 Holds Walls Up 2000 Collects Empty Beer Cans 2250 Copies Others Homework 2500 Drinks Through An IV 2750 TV Dinner Conisseur 3000 Beer Bong Expert 3250 Lives On The Couch 3500 Mentally Unemployed 3750 Prefers Food Pre-chewed 4000 Barcalounger Expert 4250 Work Induces Coma 4500 Sleeps With TV On 4750 Takes Two Hour Lunches 5000 Has PhD In Napping 5250 This Spud Has Roots 5500 Takes six hour baths 5750 Purees food to save chewing 6000 Cleans home yearly 6250 Drives a Yugo 6500 Uses weed whacker for haircuts 6750 Looks for parking meter with time on it 7000 Working on thought operated keyboard 7500 Copy and paste expert 7750 Gets meals at 7-11 8000 Frequent poser...err, poster! 8250 Trained cat to fetch beers 8500 Moved refrigerator next to couch 8750 Lives on microwaved burritos 9000 Work?! Who, me?! Never! 9250 Rents brain for extra cash 9500 Quit breathing years ago 9750 Dusts self off once a year 10000 .......and so on. Sweet i would be a beer bong expert. Cant wait to live on the couch!
  14. GT Thunder does KILLER work and even better deals. Go with the race tech gold valves. I love mine.
  15. Does your banshee ever run ? Anyways. If you say it has comp and fuel then i would check/test out ALL the electrical. Coil, stator, flywheel, plugs, caps, wires, all connections, pickup coil connections+gap, go over the harness for a broken wire, check all the grounds, if you have a extra CDI or a buddy has a known one that works, try it. Did it work before when it was together? What did you take it apart for and what was all done? Did you drop or hit the flywheel AT ALL..even a lil bit? Im sure you have a Clymers and the banshee electrical FAQ link, so go from there and check it all out with a cheap lil multimeter to start.
  16. You run 14/41 (stoke) yet? Could try a 15 out front and see if you like it.
  17. Nope. Bolt them up and run it.
  18. You sure have 500 mains in? And if you did ..... You would not even need a 500 main with your set up if you were 5000' BELOW sea level. You should be in the mid 300's on your mains and a 27.5-30 pilot MAX. You sure you have no air leak your compensating for? Did you pressure test the motor to see? You can always go through this and find the same exact setup and conditions. http://bansheehq.com/forums/index.php?showtopic=99361
  19. Have you tested out your electrical yet? Could be your stator starting to take a dump. This just happen one day outa the blue?
