firebanshee
About firebanshee
  • Birthday 04/10/1964
Contact Methods
  • Website URL
    http://
  • ICQ
    Springfield Oregon
    1993 yellow and black 12inch arm link 1 inch forward a arms 4 mill crank 68 mill cub alky 2-5 duneable lockup 39 carbs fat bastard inframe wicked out of frames big bore stock ign adj timing plate stuffed cases
firebanshee's Achievements
HQ Soldier
HQ Soldier (2/5)
2
  1. What caused the pitting ? You need to make sure the crank bearings are ok. The size and shape of the dome depends on what octane and what kind of fuel you are going to use.
  2. I would not use trinity domes at all. I had a trinity head once and kept blowing o rings and rattling plugs loose, switched to a Noss head and domes with the same cc of dome and problem went away. 21cc dome at sea level with +4 on the timing is safe for pump gas.
  3. Why would you ever want to do run a 2 into 1 set uo on any motor ? There is no performance gains running 2 into 1 set up, you will lose performance. Dual carbs set up properly will run circles around any 2 into 1 set up.
  4. I would run a duneable override also. Just having an override can add 3 or 4 bike lenghts in a race.
  5. I have v3's in my 10mil cheetah, i like them.
  6. Possible bad spark plug cap (blown resistor)
  7. You might have your slides in your carbs swapped, switch the slides and try it.
  8. This oil is also designed for wet clutches, so you clutches won't slip.
  9. Going to the desert to watch the Ducks go Tiger hunting. GO DUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
