trickedcarbine
    165
Everything posted by trickedcarbine
  1. I've set up a few trinity's, a chariot with a 35 PWK then 39 PWK, and a few Exciter set ups. Hands down the exciter out performs the other two. However the chariot and trinity are packaged to go together with ease and fit really well. The exciter needs a little massaging, but is worth it if you must go 2/1.
  2. If you have traction now, see if you can possibly soften it with the rear shock if it's not strutted. You messing with the Lock up at all?
  3. Haha. That's fucking awesome! Pay as much attention to the forks/triples as you do the rest of the bike. Takes getting used to crab walking a 2 wheel machine the first 100 feet though.... God speed good sir.
  4. Ignition issue^ Or...... In all your time reassembling it, have you changed the bushing in the kicker gear?
  5. Pull the valves apart and clean everything with brake cleaner. Note what springs are in there and post what you got. You adjust them with spring pressure. Could be you have to much pressure and they aren't opening soon enough, or they could be gummed up.
  6. Cast and forged pistons expand once hot. However they expand differently so the bore needs to be established with those needed tolerances in mind.
  7. Quick clutch? Like Hinson Quick change cover?
  8. Only one complaint I've heard on here and I'm pretty sure it was that guy ^
  9. Right on, welcome to BHQ. Your wallet is fucked!
  10. TTT All studs and bolt holes have been chased with Matco tap & dye kit. Freakin' crisp threads all around!
  11. ^ That. I'm surprised it even started.
  12. Wrong clip. Can even double up the OEM ones.
  13. ^ check that out.
  14. Spark plug boots, pick up coil adjustment .018, slides are correct?
  15. What did the builder do wrong?
  16. That's so fucked up!
  17. I've got a set where I'm getting the frame done. I can see if Moe will send them out to your place if you want. Send them back with in a reasonable time frame.
  18. 1211 is a sealer from ThreeBond. Dab as in, a little dab of sealer.
  19. -230-240ish on the main. -Couldn't hurt to have a 27.5 pilot -Needle will probably be middle-second clip from the top
  20. Negative. That's why I mentioned sending you the proper resin. I will be up front. I'm talking about lower receivers. There is a fella who has really upped the ante. Go to YouTube and search Vice News 3D printed gun. Their first few were not holding up at all. After that little documentary the gentleman who has started the whole process has begun dumping money in to resin research. They are starting to see promising results.
  21. ^ Just consider your self corrected....
  22. If I send you an appropriate resin and the program, could you print a fella a few parts?
