2005she
    2005,black,stock
2005she's Achievements
  1. can i still use the clutch cable tough .
  2. I want to geg rid of te parking break and i was wondering if i could use the same clutch cable and the same clutch lever or if i needed to get different ones
  3. Averege temp here is about 50*F
  4. Forgot to mention pipes o have toomey t5's
  5. I have a bored 0.40,ported and polished (nothing crazy),stock carbs with K&N pod filters,vforce 2 reeds, and stock head and stroke engine.My elevation is 1,726'.What should my jetting and what clip should i put on the needle?
  6. still got these?
  7. the parking break was stuck somehow but managed to fix it banshee runs all good now thanks for the help
  8. tors blqck box unplugged already will check parking break if that doesnt fix it i will do a compression test
  9. So a while ago i was going to go for a ride in my banhsee and ebrything was normal i turned it on second kick on a preety cold day more cold than usual and i just left it there to warm up for about 4-6 minutes and when i went to give it a littlr rev it will rev a tiny bit then start to bog so i thought maybe i needed more time to warm up so i left it another 5 minutes and the same thing happend and i just left it for another 5 mins and nothing so i hoped on it and tried to ride it but it will just bog so thats when i knew there was a problem so checked everything and it all seemed right it had a fresh gallon of gas and everything and the day before i was riding it and it was working perfect so i dont know what to do know.
  10. ok thank you very much
  11. will 9x8.5 wheels fit on 18x10x8 tires?
  12. Wheb i take off the E-brake thing located on the clutch lever do i need a new clutch cabel im thinking on replacing the stock levers with the ASV f3 levers.
  13. Were can i find myself vforce 2 replacement reeds.
