Did it have a spacer plate on the bottom of the cylinders? And were the cylinders ported for the crank? If it's one of the typical throw together 4mm motors on a spacer, you can easily re configure that thing and get a pretty wild motor. Get someone to make sure the crank is true, and also make sure it's welded. Have you split the cases? If so, now is the best time to do the trans. You can get it cut for duning and trail riding or just a full override for drag racing. Just go through the entire bottom end and replace all the little special clips, washers, clutch components, pancake bearing for the clutch pressure plate and adjuster, steel bushing for the kick starter gear behind the clutch. Just get that thing rock solid on the bottom end and you can go quite a few different routes for the top end later on. Lots of different cylinder options for 4mm set ups.
