Young Guns Racing
HQ Site Sponsor!
    2
Everything posted by Young Guns Racing
  1. Alright if im.gathering what I could understand from it all, thr bike runs good sometimes and sometimes not. Cuts off randomly and whatnot. Step one run a compression test. Secondly test your ignition system, and third go for a leakdown test (my bet to where ur issue is at) and see if you have an air leak. If you do idc how much u tune and jet it. She will never run correctlym good luck
  2. Sold 1 head - still have 1 left. Trans sale pending.
  3. I have a stock throttle cable id sell. make me an offer and pm me.
  4. Did you install your slides correctly? Im not too sure if they would throw this symptom at u but its just a thought. Secondly perhaps the carbs are sync'd at idle but cables are not pulling equally, did you try to sync it through out different throttle positions or at idle only?
  5. I'll throw out some offers, i need this stuff gone guys, if you need it and i got it the time to save money is now cuz i need the funds lol. Anyhow here goes a few. Carbs for parts -- $10+ride Stock Trans, complete -- $90 shipped Stock Carbs w/ TORS -- $70 shipped. Front Shocks -- $25 for pair + ride Billet Handle bar clamp -- $15 shipped Lowering kit, dont need it anymore -- $15 shipped Unless its marked "SOLD" in the original listing I still have it! make me some offers i am ready to sell!
  6. If you heat it with a propane torche before applying the acid I have found this to help getting off the tough stuff. The acid trick works good in some cases! X2 on watching the fumes too, it is some really bad stuff u dont want it in ur lungs
  7. Got two stock lengthers. Make me an offer
  8. Got me a pump and pumped.em.up to 75 psi as I am 220 lbs so I figure that'll be a good start. Thanks for all ur help guys!
  9. I asked him for pics lol.pretty sure im buying them as soon as I see them and verify they are what I need
  10. Not the ones near the heel gaurds. The rearmost brackets that keep rear fenders from drooping
  11. Texted. No one wants th is stuff? No reasonable offers will be refused!
  12. just like the add says, please let me know what you have and what you want shipped. please pm me. Thanks!
  13. is the yoshi pipe slip on, or full system? and how much shipped? a buddy of mine has an LTR and he's trying to get it to catch the ol yfz450
  14. x2 no better way to do a 4 mil, you HAVE to get port timing corrected of there will be no power benefit at all for spending that money - hell you may even LOSE some. You might as well have it fully ported instead of just "correcting" the timing. Your choice of the port work will give you a choice of the power you want to make anyhow. Stock carbs can support you up to about 70hp - hope this helps
  15. Check your reeds. If all is well, move onto a leakdown test to look for an air leak.
  16. No, ignition timing has nothing to do with compression and therefor the required octane of your fuel will not be affected by the timing plate.
  17. Cylinders sold. Im.open to offers. Make em I need cash for the new build lol
  18. way more info. step one - check plugs, try crossing coil wires and or switching plugs and see if the problem switches cylinders. Secondly, compression test. Third, teardown for leakdown test - before leakdown inspect your reeds. Give us your findings when you can.
  19. Also have a 1.5 - 2" front end lowering kit. I paid $15 for it, like to get that out of it. Stock carbs w/ TORS cables Stock Carbs for parts only. I also found 2 swing arms. one stripped of components and is black. the other is pictured as is and is gray --- SOLD CARRIER OFF GRAY SWING ARM
  20. Make offers on all this stuff I got listed. Wanting to get rid of it. Please make reasonable offers shipped to your door. I will be happy to help out some folks and unload all of these things. If these things dont sell I will probably try to ebay some of them as not to crowd this forum up. Please PM me with any interests. Thanks! 2 - old style round plug harnesses, headlights cut out in both and key switch cut out of one 1 - Stock transmission, have everything. Worked fine. Sold cases. 1 - Stock crank, rod bent and bearing siezed - possibly rebuild? Im not sure 1 - Billet handle bar clamp 7/8 bars, no idea who made it. 1 - Stock cages with carbon reeds, and many stock reed cages 2 - Sets of stock intakes 1 - Boost bottle 1 - Stock radiator 1 - Stock head in nice shape 1 - Stock front shocks painted gloss black and springs metallic apple green, monster theme 1 - set stock mikuni carbs for parts only 1 - set of stock carbs, jetted at sea level for k&n pods, toomey t5's and mild porting - have no caps. 1 - Stock airbox
  21. What year is it and would you sell the stator? If so pm me please.
