Yanbansh04
    Quebec
Yanbansh04's Achievements
  1. Yes my first question is if I can switch to a 9 degres if actually have 12* ( with the same dome, just customize (machined) it ) sorry for the english..
  2. OKay thank, but if I just buy a set of dome blaster angle its okay ?
  3. You mean I should buy blank dome and make them work ?
  4. Hi, I want to know if I can machine my big bore dome 12degres angle to get the blaster degres, because i have buy a set of dome with standard degres and I have blaster piston on my cub.. thank !
  5. What kind of wires and plugs caps are better than the original, because I need to change mine.. Thank
  6. The question is if it's normal I have only 150lbs with 19cc dome and .020 gasket with cub cylinder.. sorry if you don't understand
  7. My friends said me its because a cub have lower compression because de triple port
  8. HI, I have 19cc dome and .020 gasket, about 500ft on a 7mil cub and have only 150lbs, thats normal, however my top end have about 5-6 tank, he is new.. when the top end it was brand new, it had 160lbs, but now it is stable at 150lbs, I will get 18cc dome soon
  9. Okay, thank, for my compression, I know i have 160, have a fresh engine rebuilt since a mouth
  10. Sorry, I do my possible, I don't speak english well
  11. I have 7mm cub, pwk 33mm ( main:172 pilot 45 ) +5 timing,19cc dome, I run 3L of c12 with 7L of 91octane ( almost 1/3 ) and depending the temperature, sometimes the bike cuts a half gas, and sometimes at the top, I have try some sizes of jet and yet, the color of my plugs seems good.. and also, it looks like it gets stuck sometimes, it does so as always, but often enough and I don't know if my problem, is the jetting, fire, ignition.., stator.., Thank you for yours advices !
  12. I'm afraid to dropping, because at 172, my plugs seems poor, the colors is pale, white/brown
  13. Yes, I am 172/45, i have try 170, 175 too
  14. I want to know what causing that, when I am in 1st 2nd gear at mid-high RPM, the bike peak, and when the throttle is all open, its okay, but he didn't doing that in 3-4-5-6, and when I am in 6th gear at the end of the throttle, the bike peak or cut, i don't know if its my jetting, or the fire.. I have 7mm cub on pwk 33's carb, sorry for my poor english and thank !
