mrgreene
About mrgreene
  • Birthday 08/15/1973
    South Carolina
  • Interests
    Outdoors, indoors, I am interested in it all!
Contact Methods
  • Yahoo
    mrgreene2000@yahoohoo!
    99model,platnuim procircuit pipes,k&n filter,T.o.r.s. delete, v-force4 reeds, K&n filter and airbox mod,4" extended swing arm, itp rims LS billet rear hubs, durablue axle, Fullflight +2+1 a-arms
mrgreene's Achievements
  1. I am in need of some ten inch rear rims. Steel, rusted, it doesn't matter what they look like, just need to roll true and fit 90s model banshee.Let me know what ya got! thx!
  2. still got the headlights and they work?
  3. thanks guys! I'll give Fast a call and go out and get a few pairs of plugs and hopefully get her dialed in. One other Q, How much change in altitude or temperature warrant rejetting?
  4. I just ordered some V force4 reeds and figured I would need to rejet and after looking over all the different brands of kits I am at a loss! A 6 Sigma is the cheapest and Dynojet seems to be a bit more pricey! I think I need a stage 2 but really need a little advice on which kit is the best...for me anyways! I am currently at 1000 ft with procircuit pipes, kn filter with moded lid. Stock carbs(tors removed) and no port work done, around 85 degrees.So any suggestions on the best jet kit??
  5. mrgreene
    WTB Axle
    ISO excellent condition shee axle.Stock length prefered but will consider others,stock or aftermarket. HMU!
  6. Noticed a squeak coming from lh rear tire,gave it a shake and it has a lot of play. Removed the hub and looks like the axle splines are worn pretty bad as well as the hub spines! I went around axle spline a few times with Teflon tape and it tightened up but I know its a temp fix. Is there any other fixes then replacing the whole works?
  7. yes, synced at idle and dont have a clue on how to synce otherwise! Slides are in correctly but not sure they are in the original carb,if that matters? Did notice one carb float sticking till i gave it a tap,guess ill clean em again and check the needles. Middle notch??
  8. My bike was running great and i was always told "if it isnt broke dont fix it"! But!,i had a tors removal kit sitting around and finally decided to put it to use and install went great. Synced the carbs,adjusted idle,and removed unneccesary tors wiring. Test ride after install in my small yard everything seemed great maybe a little better throttle response in first. Went to my track to open it up and i have noticed a slight bog in second and third gear @ lower rpms. Before install even the slightest blip of the throttle it would respond and now it has this mass airflow sound/bog and its not serious but it makes me wonder if its just the kit difference or if i did something wrong! Cleaned carbs very well and still runs and idles great except for this slight hesitation now! Any thoughts or suggestions would be great!
  9. Thx guys! Maybe ill have her back up soon!
  10. I just got new arms and hiems,replacing the old LS arms.The old ball joint stud is 14mm@ top and 12mm@bottom,my new heims are slightly small about 11mm and 13mm.I know it doesnt sound like much but they are hella loose! I have been reading about reaming and wonder if this may have been done to my spindles.I was searching for new ball joints or heims but having a hard time getting correct stem/stud size so i was thinking if my spindles had been reamed maybe it would be cheaper to just buy used factory spec spindles instead of a whole new set of joints? Any thoughts or maybe a measurment of the factory spindle stud hole to compare to mine?.....purdy plssss!
  11. hi guys i found this post and my arms kinda looks like those,can any one confirm this or tell me where to find id marks or what to look for and my right upper arm was damaged sometime in the past before i got it, and im not sure its safe!Anyone know where to find a replacement without buying the whole set?Thanks for any help and i loove the site!
  12. Hey! im doing the exact build!just got my heads back and i was wondering should i use loctite red on the head studs? and what is the ring gap on 64.5?
  13. hi, im new to bhq and banshee's, bought mine bought a year ago and im still trying to wrap my mind around the twin cylinders.I read this thread and it got me puzzled!i didnt know the two cylinders were actually connected,the gauge in one cylinder and the inflater in the opposite?is it just crankcase leaking that is being tested? sry for sounding dumb,just dont understand how the pressure flows to both cylinders?
