oldskool
    4
Everything posted by oldskool
  1. If your doing a bottom end rebuild? I would use new bearings.
  2. that is so the outer race of bearing does not spin in case. It needs to be there
  3. No, we are pretty much worthless fucks. That also depends on what you compare us too.^
  4. I like all this shit talk, but this old man is hoping for these things A. Too meet a bunch of you shit heads B. Have good first experience in the dunes C. Walk away on my own D. Come home with my bike in one piece Forget that BS. We (east coast) gonna tear yall a new one
  5. Stay your course, these guys don't know jack.
  6. A manual is your best tool. The needle vavle Larry shee is referring to is what shuts the fuel off inside the carb. If it is not working properly, gas will continue to flow from tank into carb and out overflow. The float moves this needle up and down as fuel is needed to keep carb full. I suggest you check out YouTube on setting floats on Banshee. Not hard at all, but very important
  7. The sling shot pressure plate can be installed wrong. just saying. Notice where plate is with friction plates, then rotate slingshot pressure plate one set of holes. (either way) See if it gets closer to frictions. It should be close to frictions.
  8. I guess I'll have to keep the junk I got
  9. Your wanting to go with the 18cc domes, but your engine will be destroyed from detonation on pump gas with 18cc domes Detonation can take out pistons, domes, rods, crank and cases. You will be left with a tranny and clutch. 21cc domes are recommended, take the advice. Enjoy
  10. You have lots of choices. I like the +4mil stock cylinder engines. Very reliable and make plenty of HP for most folks. Enough to handle stock raptors easily. Might consider a +6 swing arm. Modded transmission. Talk to builder about setting it up for pump gas or race gas. The list of mods seems to be endless for these bikes. Enjoy!
  11. Hell, I take one them 80 hp stockers. 120hp too much for me
  12. another awesome bike from this guy.
  13. Who is trolling who here?
  14. Bwahaaa!
  15. Wow 420 ' s and need more. 350 with stock carbs?
  16. Your displacement (cc) can easily be determined once you find out what your bore and stroke is.
  17. can brakes be used with front hubs?
  18. Ha, same here except have only had one set. I happened across VF2 specific gasket kit and put two and two together.
  19. Skeeter would you like me to give your riding lesson from DDQ to Loco?
  20. Are your reed cages moving or reed pedals moving? Those are gaskets in your link. one set between cage and cylinders and one set between cage and intakes. You HAVE to use the gaskets or you will have air leaks (very bad)
  21. No, you want the needle to drop down into jet, so you would move clip up.
