oldskool
    4
Everything posted by oldskool
  1. I'll take stem. Pm me your PP address. You got axle for sale?
  2. Replace with a new piece, can't hurt. When you rebuilt carbs and did tors delete, did you clean jets and screw them all the way in snuggly? Run those air screws in all the way, then back out 1/2 turn for testing. This should give it more fuel. I'm assuming the engine passed leakdown
  3. thanks
  4. where's your air screw sitting at?. A bog can be too much fuel or too much air
  5. Its something simple. When it does not fire, check for spark. If you got no spark, check all grounds. Pull boots off plug wires and cut a 1/4 inch off of wire and put boot back on. If you got spark and it wont fire, try removing pods, open throttle wide open, then with some type squirt bottle, shoot a nice dose of gas through carbs. release throttle, turn kill switch to run and try it
  6. Don't want to intimidate you boys, But I think I'm about ready for you. Looks fast don't it?!
  7. ^^^^^^^^This^^^^^^ You also need to determine if you have a long rod crank or short rod and have your cylinders ported specifically. If you have long rod, you need the wiseco 795 series piston or blaster piston. If you have short rod, you can just run standard piston 513"s. Domes should also be piston specific such as the 795 piston is 12 degree, blaster is 9 degee
  8. Cascade
  9. 93.10 octane 10% of 1%, just heard that somewhere
  10. That is the pump cover gasket. Pull the cover off, then pull the pump/impeller out and you will see a oil seal also.
  11. My first thought was PART IT OUT, but if you want to keep it and show it who's boss. Get a manual, start learning your banshee, take your time and address one problem at a time.
  12. And you disconnected small black box under left side of gas tank?
  13. black pods sold, new price for carb set-up 135.00
  14. very nice. welcome and let er rip
  15. Set of oem mikuni with intakes,reed cages, and boyesen reeds. carbs have rebuild kit installed. choke knob is slightly bent but works. no cross over tube, but can send boost bottle. Two sets of pods with outerwears( have some wear). 165.00 shipped Complete rear brake. 65.00 shipped Ac bumper 45.00 shipped Also have used 4mil 115mm crank. 210.00 shipped 336-687-3105 Mike
  16. sounds nice. timing plate, pancake bearing and leakdown test when you get that engine together.
  17. Everybody just needs to chime in. Keep it same? Weekend before? Weekend after? Doesn't matter gets my vote
  18. I only know they are in eastern NC. Never called on them for anything. Had some nice bikes come out.
  19. RHUT-RHOW, Dammit surf........................ I guess mom's going to Busco
  20. You just need to clean cases up real good and get a visual on where oil is coming from.
  21. looking like there will be a ass of virgins there, I mean Virginians. I'm gonna oldskool all of them.lmao
  22. Yeah, just teasing the new guy.
  23. Just what we need, some more virginny yahoo's^^^^^
  24. You could go ahead and do a tors delete kit. Its not a performance mod, but makes working on carbs a lot easier like syncing,setting idle and jetting.
