Larry's Shee
    6
Everything posted by Larry's Shee
  1. Decades ago did a model car with lighting purple, very dark purple. Instead of black cherry it would be black grape. Check with someone like House of Colors.
  2. Two thoughts, float level to high,different sized jets in right carb? $.02
  3. Did you soak the fibers in trans oil before putting it together?
  4. As my Daddy used to say, "Locks only keep honest people honest" But X-2 on making imobile and locked down.
  5. Thanks! Still on the uphill side of the banshee learning curve! lol.
  6. Thanks! Still on the uphill side of the banshee learning curve! lol.
  7. Are those silencers spark arrested?
  8. Well cosidering that a two stroke would run with no pipe , I doubt that a little hole would be your problem. You need to dig deeper.
  9. How much fun does it take to wear out a 4mil? Is it better smilage than a stock stroke?
  10. WTF?????????? Bad karma headed to the northeast!!!!! Sooner or later the Fauker becomes the Faukee!!!!!
  11. Not real sure, but it sounds lean. Need larger jet when tempurture goes down. Does it do this with choke on? Is fuel fresh?
  12. If I were a banshee and had to push a portapotty I'd act up too!!! Pull air boots and visually confirm that slides are BOTH fully closing. Check caps ontop of carbs, tite, also visually check carb boots.
  13. Kick A$$, that pc or paint?
  14. Looks nice! Not all rusty, good tires. Love the color!! Other then doesn't say milage , how long he's owned it, it does look nice in the picture.If it checks out good, the price seems reasonable, I say get it !!!!
  15. I wouldn't use benol in the cold weather, it will jell up and seperate out of the gas.
  16. So, you have never made a mistake??? If you got a foot of snow in the time of a movie, if the door was shut but didn't seal good (chunk of ice, etc) you still would of had a foot of snow in the morning. If your shee is that important to you, you should have shut the door your own damn self, la-zee. My engine had duct tape over ex. and intake ports before it left the kitchen table, yeah I've got a GOOD woman. Takes a REAL man to hit a woman. As far as the "smirk", you probably had the same look when you had to tell your father you ran over the garden hose because you were to LAZY to move it.
  17. Soon as I get it we'll do the deal. I know U.S. $ is down, but was hopeing to get 75-80 for it. First we need a Prez that cares about Americans that want to work a real job, not fauks that want everything for sitting on their a$$, or illeagal alien imagrants (PC incorrect, thank you) that work for near nothing because they work for near nothing cuz they don't pay taxes and don't have to pay their hospital bill. TRPLED national debt in 8 mo. W.T.F. in H. This all proves the theory that politics are like a septic tank, the biggest, BLACKEST, nastiest TURDS rise to the top and America done $h!t the blackest of them all.
  18. Think of chamfering as a slight taper from the port into the cylinder to gently ease the rings back into the cylinder after they pop into port. You can get specifics on angle from Gorden Jennings Two Stroke Tuners Handbook or on the blaster forum there is a link to McDizzy that might show it.
  19. 2 FUNNY!!!!!!!!!!!!!!!!!!!!!!!!
  20. Didn't get many good tips when I asked same question months ago. I used Super Clean and Scotch Brite pad. Might also try cleaner for non polished aluminum wheels.
  21. With all you went through get it running over the last couple months I'd think selling it would be the last thing you would do. You have a quad with a fresh top end, plus what else youv'e done to it. Keep what you have and modd it. You'll lose your'e a$$ if you sell it now.
  22. What do you think you would want for roller?
  23. What do you think you would want for roller?
  24. What do you think you would want for roller?
  25. Do leak down test first. Is coolant level low compared to when you first got it running? Is oil level still correct? Might look for air bubbles in oil and coolant while doing test. Unless coolant is leaking fast enough to drown plug it will vaporize from combustion.Should have done re-tourqe after heat cycles.
