Larry's Shee
    6
Everything posted by Larry's Shee
  1. Is anyone aware of defective/porous castings on transfercase?? Rear half is leaking wher there is no gasket, bolt, or seal. WTF? 1998 2500 Suburban, BB,auto, 4wd.
  2. Wish fusion came in more colors
  3. Well at least it's not a 4joke
  4. That thing is tite !! Should be getting my taxes back soon. I'm tired of working on the piece of shit I have now and want one ready to rip !! Got a lot of work done to it and I needs to know, how fast does that sucker go? I need to beat my buddies full tilt YFZ450 !! He "says" he's hit 100 on it, will your's go at least that fast? He just SMOKES my beat up 87. Also, where you at? I'm down for a good road trip for an ass kicking 'SHEE!! I got time off from work coming. Thanks !! BTW< what brand boost bottle is it? I heard that a Barton Bottle doesn't make as much power.
  5. Twice as many Banshees for sale on Detroit CL than any where else. Its a tough market around here. Seen Oxy/acet torch complete for $75 !
  6. Lucky girl in pink (on right) didn't get pinched too !! Shows that stupidity in blue runs south of the border too.
  7. Of anybody , I knew Snopczynski would chime in . Thank You very much for the lead. BTW, if anyone wants to know I have made a set of pipes before. Look up the formula to lay out a cone .
  8. Try the flea market. Corner of Telegraph and Dixie HWY. While you're down that way , head on into Pontiac and get some more crack. LOLOLOLOLOLOL
  9. Come On !! Got to be someone that knows more than me !!! LOL
  10. Check that you have good spark from both wires, plug caps might be bad.
  11. You'll do anything for a buck. J/K lol .
  12. Carbine, what color is your 'Shee ? I'll try to look you up Sunday if you don't mind.
  13. Where would a person get cones to make a pipe, not necessarily for a 'Shee ? Got some from Aircone in Az few years back, but cant find anything on Google.
  14. I think what Pasi is trying to say is that the rubber is soft and the studs might ( will ) pull out easy. Mabye put a couple studs in, go pull a holeshot , check for stud loss/ damage. Then judge for yourself. BTW, check out the ice races tomorrow on White Lake if your close.
  15. July 2006 4 wheel ATV Action magazine had picture spread of ALL Banshees produced , none had white rad cover.
  16. Might either have warped head or you installed head gasket wrong , they are merked for which side is up .Make sure head and cyls are clean .
  17. What a spode !!
  18. My son's 'Shee didn't hit on both cyl all the time when he bought it. Pulled flywheel, cleaned rust off stator, cleaned inside of flywheel, cleaned rust off tabs for pick-up coil on outside of flywheel, BAMM, good as gold ! X-2 on plug caps And pick-up coil gap . Might as well clean your carbs and check for junk in the trunck, I mean tank (lol).
  19. Sure the clip isn't on the inside of the chain?
  20. Might want to drain gas tank and take a peek inside for dirt, unless you have a filter.
  21. Do a compression test, that will tell you.
  22. My son and I plan on being there. Something to do.
  23. If that thing wasn't used as a boat anchor, it should be !! My guess is that it would cost more to rehab than to get a new one.
  24. Banshee hubs fit Blaster axle ,vice versus. Blaster has different bolt patern. Don't know if Banshee ever had different patterns.
