sleeper06
    20
  1. Yes scotch rite is fine, I'm super anal bro , I just do what works for me
  2. If u have access to s glass beader I find it's the best surface finish to glue on , I usually glass beed , wash with ultra hot soapy water then wipe with ascetone with white rag . White rag is like a white glove test you'll know when it's good
  3. More detail on motor specs why don't you go 165 main leave the pilot , what needle type
  4. I ordered c4 bearings ? I'm pretty sure there Taiwan bearings
  5. Didn't ask about wheels
  6. I just purchased a bunch of main crank bearings and big end rod bearings , really reasonable priced , nice guys and they're in the process of manufacturing a 3 mm thicker 115 rod
  7. It's funny u should say that ok beast because all I hear is ,how to I get more bottom end? I urge them all to look in the dyno section and show me a motor that has bottom end . If u wanna lug a banshee around either don't expect much or don't bitch, now throttle response is something. Diffrent.. And I do agree ride it wfo I can't really think of many times I don't just smash the throttle unless slow wheelieing
  8. Depending on application and owner of engine I'll set my clearanced up a lil diffrent . The average joe blow will get more clearance than someone I know will do pm and use his engine correctly
  9. Yes it's worth the time , port entry into a cylinder Is a focal point when I port . Just my opinion
  10. 50 pilot 150-155 main n68a needle 4th clip , good staring point if your motor is mechanically sound an electronics are up to snuff
  11. That bikes gonna fly my man , that was a conservative pass and it's moving .
  12. I would say jetting is damn close, if its running like shit look elsewhere
  13. Where r u from
  14. Rite on top leave white peice in there
  15. Thought are they suck, pwks or leave stockers IMO
  16. Harness issue something not wired right , burnt harness and bad connections are common
  17. I beleive its 16 , that's what I use when they go bad, the unit I use is off a late model honda
  18. Use green lock tight all the jet ski cranks are green locktighted together, a lil goes a long way. More than likely it wasn't phased correctly , you need a jig to do it effeciantly
  19. Die grinder not the best tool choice lol
  20. Send the drum rite to redline it's cheap to have that bearing put on
  21. Are u sure on that compression, you're 91 seems on the verge to me and the 87 is a no go could have been detonating that motor the whole time , snow isn't the easiest of thing for s shee to go through
  22. Water will not suck through the Venturi in the carb very easily check the tank , hopefully that's all that happened
  23. Most people that have there configurations figured out arnt gonna share countless hours of testing, diffrent porting styles and set ups shine with diffrent designs
  24. And I wasn't talking about liquid cooled I specifically told him air cooled good luck, there's also plenty of shops that speciAlize in these engines call one
  25. This why I told you to call manufacturer direct did you tell him it was air cooled?, it's obvious your gonna do what u want anyways
